ive included a series of videos for the hard-of-reading (aka lazy people like me).. but for those who like to read, dont worry, ill be writing everything down too.
BTW if you have ANY QUESTION AT ALL just ask, i will answer to the best of my ability
Remove these ads by
Signing UpStep 1: The Basics: part 1 the basic gun and safety
if you rent a 98, it will usually not come with a stock, the barrel shown, the sight, the double trigger, or the remote line attachment
in the second picture is a barrel condom. the barrel condom goes over your barrel, just like a sock over your foot, to stop paintballs from hitting anyone when you accidently fire. most fields require that you own a barrel condom and require that you use one when not on the field.
>>>>if you like it so far rate it plus 1 here>>>>>>>>>>>>>>>>>>>>>>>>>>>
Visit Our Store »
Go Pro Today »
Although it is a good idea to support local shops...
It's useless, the 98 has too stiff a trigger to warrant a double trigger. And I don't know why you bought a 14" barrel. Those are just money wasters.
It's not the best thing to show a new player who doesn't want to spend that much as they are trying it out. They will just be convinced they need to buy all that useless junk.
Everything else is decent.
Barrel length only has an effect on barrel length, nothing else, look up PunkWorks, ask them about it.
Again, my point is that he does not need that useless junk.
(and even if it effects efficiency, it would be miniscule, so there would be no reason to get it.)
But he never says to get a double trigger or a longer barrel, he simply shows them in the picture and puts a box saying what it is. Back to the barrel, it is not minuscule, have you ever put a 6 inch barrel on a gun, shot it for a while and then upgrade/switch to a longer barrel say 12 or 14 inches long? The gun will noticeably shoot faster. Which means you can turn your velocity down, this falls along the same lines as losing efficiency when using a cyclone, you can get 800 or so shots off before and now you can only get 600-700 out of your 20 oz. my friend probably only gets 500 shots out of a 20 oz. with his A5 with cyclone. Some people will say the cyclone doesn't change your gas usage that much but it does. I play with two people, same guns one with cyclone one without. Same velocity and the one with cyclone has to change his tank about 200 shots earlier than the other.
But, I need to see some physics on if a barrel is longer. Think about it. A longer barrel will have no effect whatsoever on velocity. All of the velocity changes happen at the bolt.The air hits the paintball. If it's overbored, the air will almost immediately go past the paintball. If it's underbored, the air will keep it going. But, but but but, once the paintball is hit by the air, the paintball will keep going the same speed, and only be slowed down by things such as air resistance, blah blah blah. Oh, you say the air will keep pushing the paintball in a longer barrel? No. If it's underbored (or paint to barrel matched), then the air will be slowed down by the original push.
Again, if you don't believe me, contact Punkworks.
The only part of the barrel that affects efficiency is the bore.
If you still don't believe me, get a few cases of paint. Then fill two tanks to the same level. Then do a test. I need proper evidence. And a video if you are going to do it. And use the same marker.
Also, if you use Co2... that means that if you take one barrel off, and put another on, and there is a change in temperature, your "theory" is flawed. You can't test efficiency with Co2.
(It takes a while though)
I want it to shoot more accurate!What should i do?Buying another barrel?Please help me!!!
"The ultimate truth in paintball is that the interaction between the gun and the player is far and away the largest factor in accuracy, consistency, and reliability."
It all depends on the pressure and volume rating of the tank, Other variables may add up as well (such as the barrel length and such), but this is the most common.
takes me 5 seconds flat
1- high speed paintball (even at 260-270fps would have some effect)
2- range (if it's close enough, most of the kinetic energy will land on the target)
3- personal pain threshold (this is different for everone, how much "pain" can a person take, bruises, welts or not)
:-D
This is our forum in South Africa where we discussed this:
http://paintball.co.za/forum/showthread.php?t=9514&highlight=sniper+round
Here's a YouTube video where they popped a few of the sniper rounds.
http://www.youtube.com/watch?v=9rsVXFL48Sk
Here's another forum showing a photo of the new round that Tiberius has brought out.
http://www.automags.org/forums/showthread.php?t=239743
barrel efficiency
As for rifling, bullets and paintballs are two different things. Bullets are solid, but paintballs are filled with liquid. Rifling is ment to spin bullets, but this does not work well for paintballs. For an example go try to spin a hard boiled egg on a flat surface. It balances and spins pretty well, but if you spin an uncooked egg it will wobble and stop. This is because you are applying force to the outer shell without applying force to the liquid inside.
oh yeah, and i want to start paintballing, but don't know how to get started...
you seem more informed than most...
could you help?
The experience debate means nothing and cannot be proved over the internet so I think we should drop that. Your comments about range can be proven wrong by anyone who has taken high school physics. Any two objects of the same shape and mass, if they are traveling at the same speed at the same angle, will travel the same distance unless another factor is added (such as spin, but because the stock barrel on the X7 is a smooth bore that is not relevant). Your velocity argument is unnecessary because no field allows you to shoot above 300fps and all guns can do that. Both the X7 and A5 use the same simple single tube blow back design (animation here) so neither has a significantly higher firing rate. As for accuracy, it is mostly paint to bore match (article here). And I have shot an X7 before, and I personally prefer an angel, autococker, or automag. While the X7 is a very customizable gun I seriously doubt it is the future of paintball. It may be the future of scenario and millsim paintball because of its out-of-box milsim style and the amount of upgrades available, but the 98 and kingmann MR series are right on its heels. Is that a satisfactory response?
secondly i would recommend an ion which runs about the same price and gives much higher performace.
Action Village sells all things paintball and the ion blows everything else out of the water in sales.
I made an instructable that uses a paintball co2 tank to euthanize prey animals to feed to snakes. I'm not a paintball guy, but a few folks had questions about the names of the parts that I used to build it. Could you take a look at it and tell me what the parts are called so I can edit and make it better?
Here's the link:
http://www.instructables.com/id/SXCZ6V7F7PCS22O/
You can see the tank, and whatever that valve is and that other threaded connector that grips the black tube. Do they have actual names so I can tell the people what to buy?
recommend - rap4 link
my favorite -
