Your Sharpie Marker Revived
2,631
62
5
Published
Introduction: Your Sharpie Marker Revived
About: Garvey's Office Products is the largest family-owned office supply dealer in Illinois. We are the nice guys in office supplies!
Looking to expand the life of your Sharpie marker? With some basic office supplies ingredients, you can save your favorite marker from the trash!
Step 1: Grab Your Supplies
To revive a dried out Sharpie marker, you will need:
  • Your marker
  • Rubbing alcohol (any brand or proof will work)
  • Eye or ear dropper
  • Pliers (you may need two if your marker is really old and stubborn)
Step 2: Pull Apart Marker
Carefully pull apart your Sharpie marker. If you have an older marker, you may need two pliers instead of one. You will hear a loud "click" when the marker detaches. This is normal.
Step 3: Remove Ink Pad
Remove the ink pad from the marker container. Be careful to only touch the sides or you'll stain your fingers!
Step 4: Saturate Ink Pad
Using your eye or ear dropper, suck in the rubbing alcohol. Take your alcohol and proceed to saturate your ink pad. Tip: Start with 2-3 drops then wait. If you over saturate your ink pad, it will drip ink. We have noticed that 4-5 drops works perfectly - but this may vary by marker.
Step 5: Reassemble Marker
Reassemble your marker. You will hear the pop again when you put your marker back together; this is how you will know it's secure. Wait 1-2 minutes before using. This allows the ink pad to be fully saturated and ready to use. Then enjoy your newly revived marker!
BONUS TIP: You can revive your marker as long as the ink is not dried out. We'd recommend 3-4 revives, then it's time for a new marker.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    5 Comments
    Sometimes the more you know. :)
    I FINALLY had one of these go dry at work so I could try this....so TOTALLY amazed my co-workers, haha. I used a syringe and some methyl hydrate in a pop bottle cap, worked like a charm ~ THANKS!
    I've done this before but used Lacquer thinner being how Sharpies are Lacquer based. But if alchocol works, go for it. Thumbs Up.
