Print the pcb layout on to paper. Push the LED in to the pcb where it's marked.(Flat/short side of led is -) Push the resistor in. Solder or glue the ...
can u plz tel me why particularly u selected a 510ohm resistor only...and also tel me why particularly u selected 3v flat button battery only and also help me with how to select resistors and batteries for any different simple projects
I used a 510 ohm resistor only because it will make the led light up at the brightest, also I didn't use a 3v button battery, i used a 9v. I used the 3v button battery because it's compact, and you dont need a resistor when you use a 3v button cell battery.
i made one of these as a fish lure once. believe it or not it works under water. i didn't have to glue the electrode wire or solder them onto the cell.i used a little pressure from the plastic case i used. have fun....
The flasher LED attracted fish. Catching the fish required knowledge of bait and lures. I am working on another attractor- a buzzer. It is a miniature relay connected as a buzzer. Hope it works.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
and i will add schematics
