Step 2Cheap land
Unfortunately I made the house before thinking on making an instructable, so I don't have detailed pictures of the whole process.
For the cage I used:
- Original hamster cage
- Bolts, nuts and washers
- 42 L Plastic storage box
- Plastic mesh
Tools:
- Dremel with cutter disc / or Hot knife
- X-Acto
- Sandpaper
- Permanent marker
- Drill
- Hot glue
First you need to fix the bolts in the wire cage. Then you measure the door and mark it in the side of the plastic box.
Cut the side of the plastic box with the dremel/hot knife.
Drill the holes for the bolts in the correct place.
Join the cage to the plastic box and fix it with nuts.
If you noticed, there is a small wall separating the cage and box, despite the hamster being able to climb it, I made a small ramp from two small pieces of wood.
I also cut the box lid and placed some plastic mesh with hot glue. This way I can see through the roof and the air flow of the box is improved.
Also, some kinds of plastic tend to absorb and hold on to pee smells -- usually the softer, more flexible plastics. But then, those are the plastics that tend to smell the worst on their own anyway.
