ZT465 Knex Assult Pistol
PlayKnex by
5,375
13
47
Posted
Introduction: ZT465 Knex Assult Pistol
true trigger and magazine included.
First tho' I would advise yhat you have already built a few other guns of your own before you build this one.
guns you should build:
http://instructables.com/id/EGRS0Q9ZD9EZ7BG2FT/
http://instructables.com/id/EDWA7BXQ0YEV2ZIEV0/
http://instructables.com/id/EE0QQZ1L99EY95SAZT/
http://instructables.com/id/E631BN2OIPEUSZO5KN/
http://instructables.com/id/EIHN3XU1B7ETVPJZCX/
Im only saying this so you get a feel first of all the guns
you will need:
Rods
3 yellow
14 white
6 blue
15 green
Connectors
12 dark grey
7 yellow
4 orange
11 green
2 white
4 light grey
Other
2 blue spacers
12 hubcaps(tan clip connectors)
Step 1: Barrel
make the following this will be the barrel follow the instructions just as I am showing you here.
pic 1:make this
pic 2:add this
Step 2: Handle 'n' Trigger
make the following
pic 1:make this remember to look at the other pictures too.
pic 2:the picture from the side view.
pic 3:add this bit.
pic 4:this is the actual trigger you will end up pulling.
pic 5:make this its pretty simple.
pic 6:now add it on.
Step 3: Extended Barrel 'n' Ram
the barrel and extended ram.
pic 1:ram(left) and the extended barrel(right).
*important note*
just 'cos I say "extended barrel" it still means you have to build it.
pic 2:insert the ram in the barrel.
pic 3:put the extended barrel on the front end of the barrel.
Step 4: Asembelly 'n' Elastic Bands
but it all together
pic 1:put the handle on the end of the barrel(sry the elastic bands are there theyre not meant to be.
pic 2: attach the other end of the trigger like so.
pic 3:sorry the pic is blurry its quiete a shame because this is the most important part of all you need o adjust this quite a lot for the gun to work that is why I said to make a few other guns first. If it doesent work private message me or leave a message on my orange board.
pic 4:This is important to. the elastic band here need to look like I am showing you because the gun isnt meant for to much strength altho' it does need a bit to work.
Step 5: Loading 'n' Shooting
To cock the gun just pull back the ram. if the trigger part doesent get in the way make sure you reapeat step 4 or that your hand is'nt in the way.
once youve completed that give the trigger a sharp jerk,and, if your lucky, the ram should fly forward again.
Ammo type:
1.suprisingly the best ammo is a yellow rod with a red connector on the end.
2.5 green rods just open the magazine and insert them in.
thanks for making
bunduk
  • Minecraft Challenge 2018
  • Sew Warm Contest 2018
  • Gluten Free Challenge
47 Comments
not even a real true trigger...
It is very complicated. I built one that is less complicated, but the prestations are the same, though.
those arnt black ball joints. there blk rod/connectors
hey bunduk i made further mods for your shotgun while i was rebiulding it after pulling it apart so i could make some other guns. 1st i made a mod for the pump which replaces the pully system, 2cd i made a longer body on the back and has a shoulder arch which goes over ur shoulder and under ur armpit it better acuracy too and last but not least a hinged true trigger. p.s tell me if u want me to post it or if u want me to email u the instructions so u can make it and decide if u post it or not and heres a picture of it
yo kewl post it
ok then thx cause i dont want gamer 5 bugging me again ill put it on the ealiar version as a edit
i have one question....how does the mag work, please post a vid or instruction to load...other than that great gun!
