I have recently got more sealed lead acid batteries so I can now power my ZVS flyback driver up to 36 volts! I will try find some time to make an instructable about making one of those beast, at the moment, I can show the vid of it working. :-)
Visit Our Store »
Go Pro Today »
but the arcs climb nicely.
I am pretty sure it does, probably in a newer NST, but I never seen the insides of one of those things.
I guess I wanted to know more of what this is used for.
A ZVS is Zero Voltage Switching (I know, its very technical :P)
A NST is Neon Sign Transformer
You might then ask, "why not use their more stable diatomics or other molecules that are gasses at SATP?" One reason you might want to use noble gasses is that all of their orbitals are completely filled and they are monatomic in their standard states, in other words, they have the lowest excitation energies. If you use diatomic, triatomic, etc. gasses, then you need to break more stable sigma, pi, etc. bonds than you would if you used a monatomic gas. This translates to a lower breakdown voltage for noble gas excitation and this means that you can use simpler equipment. For example, to make a good sized Argon discharge a few feet long tube, you don't even need a vacuum pump with a standard 20kV power supply. To contrast to this, you would only be able to get an inch long discharge in free air (mostly O2 and N2 gas) with the same power supply.
Welcome back, Plasmana!
I will be going in and out of instructables as I got to do college, spending time with family, doing experiments, and watching youtube.
Summer holidays is coming up so Ill be able to spend more time here :D
(At the moment, I got too much experiments I want to get done)
I will publish an instructable of it soon too.
still really cool to watch though :)
