3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homebrew Laser Cutter made by Zach Radding
Step 2Zach's first lasercutter
Zach\
This first version uses a Roland digital pen plotter to move the cutting lens, and incorporates a number of lasercut mechanical parts.
Zach used the following components. Prices have changed (fallen) since '94 when he bought his, and some
of these things are no longer manufactured. Similar components are available, or you can look for
these on the used market.
Here are the components he used:
CO2 laser tube: Synrad G48-2-285 25 watt laser cost approx $2000
Power supply: Power One Model SPM3E2K 28 volt 27 amp switching power supply. cost approx $300
Mirrors: Four high quality front surface mirrors ~$20 each.
Focusing lens: must be made specifically for the laser wavelength. It must be optically clear to this
color light or it will etch and melt. Zach's lens came as a unit with a 45 degree frontsurface mirror
from Synrad for ~$600
3 comments
Jun 29, 2008. 11:45 AMTheMadScientist says:
not very well known, but you can get incredible mirrors by cutting them from harddrive platters. if you don't have a glass cutter, you could also use some of the aluminum ones. both are polished so that not a spec of dust is on them originally, i'd spray coat them as soon as you open the harddrive, or fingerprints will settle on them, but they're as perfect as you can get.
Dec 7, 2008. 7:21 PMalphaseinor says:
What would you use for a spray coat?
May 20, 2010. 3:03 PM2bytes says:
 good question...
Dec 2, 2010. 6:55 PMhintss says:
hard drives are shiny. also united nuclear sells tiny circular mirrors, less than on inch in diameter, and they're made for infrared lasers. they're in their death ray parts category...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1252
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
