Step 5The Laser tube
It's a Synrad G48-2-285 25 watt laser cost approx $2000
Fans in the blue enclosure (absent in this photo) blow air into the holes in this lucite enclosure around the laser. This cools the laser and keeps smoke and other dirt from getting on the front of the laser. This is a good way to keep the laser from burning a hole in itself.
This unit has a number of nice features. It takes a relatively low thirty volt supply. It steps it up to a bazillion volts internally. That's how many volts it takes to make the laser un-lazy. The unit also has a convenient DB9 connector
with a TTL level (five volt) input signal line to turn the laser beam on and off. You can connect a PWM (pulse width modulated) signal in here to turn the laser power down to any level you want. Zach's PWM is at a frequency of 20khz.
![[Make] a Tie, Scarf, Belt, and Cord Rack Thingy!](http://img.instructables.com/files/deriv/F68/B7R4/GYJXYIO3/F68B7R4GYJXYIO3.SQUARE.jpg)
Cheers :)
