Introduction: Zebra Purse, Folder, or Whatever
Picture of Zebra Purse, Folder, or Whatever
This zebra print briefcase clutch with its sleek design; is the perfect answer for those who like the looks of large bags but don't like how heavy they are. Works great for casual and dress. This clutch is designed for keys, phones, papers, and wallet or make-up-bags. It can be used as a file folder as well. This would make a great kids craft for gifts for everyone.  Follow through and I will show you how it was made!
Step 1: Supplies
Picture of Supplies
1 File Folder 15 3/8" wide X 11 1/2" long ( I guess that is what this is called, I bought it at Goodwill).
Clear packaging tape
2 Sided tape
Zebra print Duct tape
Wax paper
Picture of zebra I printed out a coloring page online for the zebra face.
Step 2: Tools and Optional
Picture of Tools and Optional
Computer
Printer
Marker or pen
Exact o knife optional omit if kids are making this.
Scissors
Ruler
Ribbon, handle, or flowers all optional
Cleaning cloth and alcohol optional
Disclaimer: If using the Exact o knife it is extreemely sharp and it will cut you. If making this craft with kids do not use it.
Step 3: Clean
Picture of Clean
I bought this file folder at Goodwill so I thought it was best if I cleaned it with alcohol and a cleaning cloth to make sure the tape would stick to it.
Step 4: Print
Picture of Print
Find a zebra picture you like online or go to the link I provided and print out a copy there. If you print out one there,  scroll down to the 2ND picture because it is printable BUT click on the picture to make it larger or you will get a small picture. I would print one picture and if everything is the way you like it then print out more copies. I thought this would look real cute with a picture of the zebras butt on the back of it and make a tail from braided embroidery floss. I did not do it because the picture quality of this photo was not very good. I used pixar to edit a photo and it did not turn out very well.
Print out the zebra picture.
I would print extra in case you make a mistake.
Here is the link that I used: http://scrapcoloring.com/news/zebra-head
Step 5: Mark Cutting Line
Picture of Mark Cutting Line
Mark the cutting line. You should mark it so you will have 2 pieces. The eye section will measure 6"wide X 3 3/4"long and the nose piece should measure 6 " wide X 2 1/4" long.
I did not mark my picture like I am telling you because I was figuring it out.
Don't cut the pieces out because in the next step we are going to tape the page to wax paper and then cut it out.
If by chance you did it is OK you will be taping 2 pieces instead of one in the next step.
Step 6: Covering the Picture With Tape
Picture of Covering the Picture With Tape
  1. Cut out the zebra picture.
  2. Take a piece of wax paper larger than the zebra image and put it on a table.
  3. Stick a small piece of the 2 sided tape in the center of the wax paper to hold the zebra picture in place while you tape the zebra picture to the wax paper.
  4. Lay the zebra picture on top of the wax paper centering the zebra picture over the wax paper.
  5. Tear off a strip of packaging tape larger the the zebra image and beginning at the top or bottom edge tape over the picture but make sure you overlap the edges so the picture attaches to the wax paper.
  6. Repeat this across until all the picture is covered with tape.
  7. Cut out the outline of the zebra and remove the wax paper.
  8. Cut the zebra on your marking line.
  9. You should have 2 pieces now that are covered with tape.
Step 7: Taping to the Brief Case
Picture of Taping to the Brief Case
Place a piece of the 2 sided tape under the flap on the front section of the file folder.
Lay the zebra's nose section under the flap and center it between the two blue tabs.
Lightly stick it to the tape, re-position if necessary.
Next place a small piece of 2 sided tape on the top flap.
Lay the eye section on the top flap centering and matching the zebra's stripes.
Step 8: Attach
Picture of Attach
Add more 2 sided tape under the picture to keep it secure while you attach the picture sections to the file folder using the packaging tape.
Using the packaging tape; tape along the edge that overlaps the nose so it will turn under to form a nice edge.
Repeat this for the edge above the nose under the flap.
Step 9: Duct Tape
Picture of Duct Tape
Now using the Duct tape begin forming a frame around the zebra.
Continue across the bottom section of the file folder using the duct tape.
When that is done then tape the top section.
Lastly Duct tape the back and the inside flap.
Step 10: Embellish
Picture of Embellish
I did not have any embellishments that really suited this bag but I felt it needed something to set it off.
If I had purchased the file folder new; I would have bought one with red , white, or black instead of blue tabs and handles.
It would have made this bag come alive. I am not that fond of black and blue together.
I did not attach the brown purse handle to the bag because the handles were fine, but I wanted to show how pretty it looked even better if they had been a different color! It made the bag look quite classy!
Step 11: Sunshiine's Final Thoughts
Picture of Sunshiine's Final Thoughts
I was totally surprised how cute this purse turned out! I am definitely making a few more and share them on Instructables!
I hope everyone likes it as much as I do!
In closing I would like to thank our instructables company, sponsors, authors, readers, and members; for making this community a great success! Many hours and hard work has been put into making this place the best DIY on the Internet. Have fun and thanks for stopping by and I hope your day shines!
Sunshiine
sunshiine (author)2013-07-02
It was great fun! Maybe you could make one with duck tape and use a picture of a sock monkey, I think that would be better than this actually. Thanks for sharing.
sunshiine
chazgottlieb (author)2013-01-18
Great project! It makes toting the office home a lot more fun! Thank you for the great idea!
sunshiine (author)chazgottlieb2013-01-19
Thank you for stopping by and commenting! Have a splendorous weekend!
Sunshiine
Penolopy Bulnick (author)2012-09-04
So cool! That zebra blends in wonderfully!
I love it! I think a red rose would look great! Or a heart and a skull or something. I can't do all that computer image art stuff. I can't paint either but I know a lot of people here can. Make duct tape look classy! Thanks for commenting! Hope your day shines!
Sunshiine
PotatoCoffee (author)2012-09-02
I might try this with a tiger pattern. Nice job! Have a great day!!!
-PotatoCoffee
sunshiine (author)PotatoCoffee2012-09-03
They had a tiger on that link I shared. You can color it also! Hope your day shines!
sunshiine
PotatoCoffee (author)sunshiine2012-09-03
Thanks I'll check it out!
Do you plan on drawing your own tiger?
Possibly, probably a cartoon one!
Cool, I hope you share an instructables when you have it made!
Sure!
Can't wait!
Thanks!
UW!
What?
U welcome
Oh.
Did you find the duct tape?
sunshiine (author)PotatoCoffee2012-09-02
I almost bought a tiger print duct tape last night! I should have. I forgot to look for a folder though. I'll bet it would be really cool. Thanks for stopping by! Keep on shinning!
Sunshiine
Tiger duct tape? I've never seen that before?! BTW I don't like bruising my shins!
Yeah I know I misspelled that! I am not deleting it because then you get that message. No haven't seen the duct tape but you could use the zebra stripe on the white tiger for contrast. Or find a duct tape that you like. Black would work, Or a gold! You might find gold around Halloween.
Ah I only mind spelling mistakes if iproberry does them (I'm his editor). And where do you get the colourful tape from? Is it Wal-Mart?
Walmart here had the tape in the sewing section but they had it in another area also, maybe the office supply or paint section. I am sure Hobby lobby has it also. You might be able to make your own by using a strong 2 sided tape and covering it with fabric or printed craft paper like scrap-booking paper. How about covering the boarder with scrap-booking paper and overlay it with the clear packaging paper! That would work. I like the look of the clear packaging tape because it gave the surface a shiny clear look. I tried a non yellowing contact paper and it did not look good at all. They also had some Duct tape at Home depot in the paint section. Hope this helps!
Sunshiine
I looked in Wall-Mart and I couldn't find any. I'll have a look in the hobby store that's down the road. I have a binder I'd like to decorate!
Oh yes, it will look great on a binder. Are there any hardware stores near by? You might check with them. I live in a small town so we don't have a lot of stores here. Michael s would work too.
Relativly close, but far enough to be driven.
You are really fast at commenting! Well. hopefully you will find a store that has something.
I know! It's one of my many talents!
I guess!
=D
Very quick!
I know right!
Kitana Kellaway (author)2012-09-02
Thats really cool!!
Thanks Lilly! I have missed you! Hope your day shines!
Sunshiine
bajablue (author)2012-09-02
Snazzy!
sunshiine (author)bajablue2012-09-02
Thanks! I loved the little guy!
About This Instructable
2,086views
24favorites
License:
Bio: I am married with two children. Spring, summer, and fall are my very favorite times of the year. I love the sunshine thus the reason ... More »
More by sunshiine:How to Process Card and Dye Raw Wool Score Shape Color and Stencil Bread for Bread LoversCreative Pickled  Blueberry Recipe for Foodies
Add instructable to:
