Remove these ads by
Signing UpStep 1: Problem
The thin cut-off I was sawing had been sucked down into the blade arbor area and crushed my table saw insert on the way through. Luckily this all happened very quickly and nobody was hurt, but it really alerted me to the fact that there is a better way to use the table saw to to cut thin slices of of wood - get yourself a zero clearance table saw insert.
Zero clearance inserts minimize tear-out, support even the smallest and thinnest of cuts, and even make your table saw safer.
Unfortunately they don't clear dust as well since they leave no room for air to be sucked down if you've got a dust collection system for your table saw, but if you use it just for small detail cuts that doesn't really matter much. The benefits far outweigh the drawbacks on this one.
Visit Our Store »
Go Pro Today »
Since the insert opening is much more narrow than the standard insert, large chuncks will not be jammed. But smaller cut off pieces can still get caught. It happened to me. I made my insert from a 1/8" phenolic sheet (micarta). When a small piece jammed it gave a "whang", but did not shatter.
Table saws aren't the only tools that can be improved with zero clearance inserts. Looks like it's time for me to replace the insert on my metal dedicated band saw :/
I used my 90 degree zero clearance insert as a template however I had to move the finger hole since the original 90 degree location puts your pointer finger right over the blade when it's in the 45 degree location. I also put screws on the side and bottom of the insert so that the insert could be locked into position. I didn't do any height adjustment options however, just planed the piece of walnut down on the planer so it was the exact depth of the insert inset.
Also, you've got do remove more material on the bottom of the insert than you'd expect to have the blade clear when it's raised up...at least that was my experience.
Thanks again Bill WW.
I don't have a planer, alas. Also, did not have any wanut until two days ago when my neighbor gave me a couple of rough planks.
Now designing and building a rip fence, may turn the project into an Instructable. It will be more of a "how to design and build a modification" Instructable.
Thanks for the comment.
