Zero: Energy Waste
77
Posted
Introduction: Zero: Energy Waste
We will create a mock up of what can be a smart home device that is mounted on your wall in order to track and control the amount of electrical energy your home uses.
Step 1:
Open Sketchup and draw a rectangle on the X and Y plane, the square measures 50mm in length and 30mm in height.
Step 2: Step 2
Close the square.
Step 3:
Draw a 3mm base on the bottom of the rectangle.
Step 4:
Draw a curve on the outside of the rectangle. It has to touch the top and bottom of the rectangle.
Step 5:
Draw a second curve, 3mm away from the other curve, this will create the thickest of the wall of the device.
Step 6:
Step 7:
Delete the outside edges to create the curve wall.
Step 8:
Create the top by drawing a curve a little more than 3mm in diameter.
Step 9:
Draw a hook, this will create a place for the glass to rest.
Step 10:
Erase the outside edges to form the curved top.
Step 11:
Erase the top line of the rectangle, as well as the vertical line on the left of the rectangle.
Step 12:
This will leave you with the main profile, create a lip by drawing a sort of S in the middle.
Step 13:
Curve the edges of the profile by drawing curves.
Step 14:
One you have your profile, copy and paste it two times.
Step 15:
Draw a circle o the X plane, the radius being the length of the profile.
Step 16:
Erase the bottom part of the profile.
Step 17:
Using the follow me tool, press the profile and then drag it around the main circle.
Step 18:
You will now have a 3D figure. This is forming the top of the device.
Step 19:
Draw another circle for the second profile.
Step 20:
Step 21:
Again, using the follow me tool, press on the profile and then drag it around the circle that we created on the previous slide.
Step 22:
Once you rotate it, you will have the bottom part of the device.
Step 23:
Go to the bottom view.
Step 24:
Insert text.
Step 25:
You can name it as you want.
Step 26:
Raise the letter by 1mm.
Step 27:
You can check if the parts will fit in when you move them around into an assembly.
Step 28:
You can now export the pieces into a .obj file.
Step 29:
Open apex.
Step 30:
Import the .obj piece and click file print.
Step 31:
You can see how the pieces are going to be printed from top to bottom.
Step 32:
This is now your 3D printed piece.
Step 33:
Paint it using primer.
Step 34:
Cut a piece of acrylic being 90mm in diameter, you can create wedges in order for the piece to fit perfectly.
Step 35:
Mount the piece on your wall.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
That's a nice casing, you should upload the schematics and code for the electronic components. :)
