3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Zig Zag Structure - Cardboard Chair
This whole thing was a University project so documentation is a bit spotty.
I designed a robust chair, it survived many a party (unlike most fragile chairs I've seen) and the principle could be applied to any household furniture.
I've included a step by step of how the basic structure goes together (along with an IKEA type instruction book).
But the best bit is the video of me putting together a whole chair.
- Enjoy
CBC - manual 2.pdf(1684x2384) 296 KB
Step 1Basic Structure
Basic Structure
This will take you through making the basic structure, you can make whatever you want out of it. The pictures (and notes) do most of the explaining.
The first layer will need 3 strips of card, one longer piece to create the zig-zag and two 'sandwich pieces'
Mark out and score your longest piece at 42mm intervals on each side, make sure to stagger the lines so that when scored it will fold up properly (fig.2)
Take one of your other pieces and mark out and glue it (fig.3)
Now carefully glue down the zig-zag piece, you may need to use pins or tape to hold it while it dries.
After about 10 minutes you can glue the second sandwich piece on top.
Use something heavy to weigh it down and make sure it all sticks. (fig.4)
You can continue to add as many layers as you need (fig.5)
you can make this stuff in big sheets and cut it to the right size later, or you can cut out the shapes you want and build them up layer by layer. (like i did)
35 comments
Oct 11, 2011. 10:18 AMKiteman says:
So, you corrugated some corrugated cardboard?
I can't work it out - is that "meta" or "über" corrugation?
Oct 11, 2011. 11:09 AMcrossfire says:
I'm going with über X2!
Oct 11, 2011. 8:08 PMilpug says:
dicorrugated cardboard? Bicorrugated? hmm.
Oct 24, 2011. 12:07 PMim3733 says:
POLY-Corrugated. or Corrugated^2
Oct 24, 2011. 8:34 PMilpug says:
Nice.
Oct 14, 2011. 8:26 PMP.Bechthold says:
Nice work. Aesthetically pleasing and creative use of materials. If I may ask a design question though:
How does the triangular corrugation add to the structural integrity of the chair. Of course it will help resist sheer (or is it lateral) force, but it strikes me that the primary challenge in furniture building is downward force. So my question is, will the triangular corrugation improve the chairs ability to hold weight, or is the vertical and multiple layers of cardboard in the arms the only weight bearing design feature?
Oct 18, 2011. 10:59 AMclaudg1950 says:
I am probably not understanding your question (I suspect you already know what I am going to say) but to complemeht the author's reply:
You are right that in a chair probably largest loads are downward. So what vertical corrugation does is increasing the stability of the design. It increases what is commonly called Moment of Inertia. Take a sheet of paper and stand it on edge. It will support no weight. But corrugate it, or transform into a vertical tube, and it will be a lot stronger.
Also: for strength, the amount of material is no more important than the placement of such material: for a sound (and not overweight) structure you want to put the materials under load as separated as possible. Thus, what corrugation also does is to separate one flat paper from the other.
There is a video where aircraft designer Burt Rutan shows that a mini bridge made of two lateral supports and a horizontal piece of, say, 1 inch rigid (insulation) blue foam cannot hold the weight of a single house brick. Equally, two layers of a thin fiberglass+resin laminate cannot support the brick either. But if you epoxy glue one fiberglass layer at each side of the foam (a sandwich structure), the assembly (FG-foam-FG) will support, without even bending, the weight of many bricks.
Oct 18, 2011. 7:30 PMP.Bechthold says:
Nice. Moment you said moment of inertia it clicked. Great examples, by the way. Really helped me understand. Cheers!
Oct 17, 2011. 9:59 AMkarlpinturr says:
Nice - especially the integrated cup-holder!
You can get adjustable hole cutters, similar to your circle cutter, for drills - though I don't know how well they'd cope with the thicknesses you're working with here.
A couple of questions - how did you figure your seat-tubes layout? And is it as comfy as you think/thought it should be?
Oct 18, 2011. 12:20 AMkarlpinturr says:
Thanks for that - I'll have to look on Amazon for the book, as well as finding a chair or three to measure.
Just off the top of my head, keeping 2 large tubes (one at the front, for comfort on the backs of your knees, and one at an appropriate point to support the lower back) might be an idea.
Oct 18, 2011. 2:33 AMkarlpinturr says:
Thanks again.
Knowing my scatterbrain self, I now definitely want the "Architect's Pocketbook" (and given the variety of projects on Instructables, I'd suspect your explanation will cause a bit of a run on it) ;-D
Oct 18, 2011. 1:32 PMclaudg1950 says:
No doubt the book might be interesting, but at least as a first approximation, you CAN find similar information on the web. A rapid search showed these:
http://www.fas.harvard.edu/~loebinfo/loebinfo/Proportions/humanfigure.html
http://en.wikipedia.org/wiki/Ergonomics
http://www.valuecreatedreview.com/design.htm
(This last reference links to a few free useful PDFs on standards.)
But measuring existing furniture should be a safe way to go.
Oct 18, 2011. 3:43 PMkarlpinturr says:
Yes, you can find stuff on the web - IF you can figure out the right combinations of words/phrases to filter the extraneous search results to save having to scroll through thousands of pages full of the most tenuous (if any) link to your subject... (Sorry, rant over - for now).
And a bit of memory-jogging doesn't go amiss, either. To that end, your bracketed comment reminded me of "The-Blueprints.com", so I dug out an old link, had a search on the site, and found some chairs on:
http://www.the-blueprints.com/blueprints/misc/furniture/
If nothing else, they'd save 'you' the measuring of those particular chairs - though it may still be necessary to do some maths to figure averages you can transfer to your own design(s).
The site seems mainly 'dedicated' to "Planes, Trains and Automobiles", but each of these tends to have at least one chair...
And they have a 'Humans' section, so you can sort out proportions.
You'll need at least a free account to do much of anything (basically, downloading as graphic images, via the right-mouse-button), but a paid-for account will let you actually download usable files.
Oct 19, 2011. 1:40 AMkarlpinturr says:
That's odd - I just downloaded this Adirondack Chair - both by right-clicking AND via the Download button - and I don't have a paid-for account, just the free one (or am I mis-interpreting your problem?):
Oct 19, 2011. 3:30 PMkarlpinturr says:
I believe so - there's been a lot of re-organisation recently (and it may still be going on), and there may have been a newsletter mentioning something along those lines.
Oct 18, 2011. 11:04 AMclaudg1950 says:
It is one of the nicest cardboard works I've found so far.
A kind of furniture that I might seriously consider using to furnish a weekend house. Congratulations.
Oct 17, 2011. 7:49 AMblkcoffee4me says:
Great Instructable, but I'll have to keep the catnip off the chair for fear that my cats will shred it to pieces.
Oct 16, 2011. 2:15 PMSlashmasterAeoniX says:
Will it keep it's structural integrity if you paint it? I know that wet cardboard tends to be flimsy... Nice instructable, by the way!
Oct 16, 2011. 7:32 PMjarrelb says:
most excellent design...i also luv the food analogy....i thinks u has a food fixation lol
Oct 16, 2011. 5:22 PMDragonDon says:
Ever since hearing about cardboard furniture I have been itching to make some. 'ibles like this help keep that itch alive till I have a place to work and not annoy the wife :) Thanks!
Oct 16, 2011. 4:05 PMiceng says:
And it can be scaled up, nice work.
A
Oct 16, 2011. 3:26 PMpcgirl says:
Very nice - though a little small for my backside. LOL
Oct 16, 2011. 8:28 AMBochiechio says:
Just don't spill anything on it.
Oct 13, 2011. 7:45 AMarpruss says:
Very nice.
When I use cardboard tubes to make telescopes, I paint them inside and out with a 50:50 mixture of carpenter's glue (Titebond II) and water (and occasionally some water-based paint mixed in), making them really wet and letting all this soak in. Two or three coats like that, and the result is a very nice and hard tube that can be used outdoors (though I wouldn't want to keep it out in the rain--Titebond II is water resistant but not waterproof (Titebond III would be better, but it's more expensive)). You can sand it, too.
Oct 11, 2011. 10:05 PMl8nite says:
that's a great looking chair !
Oct 11, 2011. 3:27 PMrimar2000 says:
Good work!
Oct 11, 2011. 1:20 PMbertus52x11 says:
This is nice!
Oct 11, 2011. 12:57 PMzazenergy says:
great job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:madmanmoe64
Currently studying Architecture at University of Brighton, but spends spare time cramming gadgets into Zippo Lighters and movie props.
