3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Zig Zag Wire Wrapped Ring
Next week I am going to be teaching a couple of workshops at my daughter's Jr. High School.  One class is called 'Fun with Wire'.  Here is a sample project that I designed for the class.
Tools:
Ring Mandrel, wood dowel or pipe to form ring base
round nose pliers
chain nose or needle nose pliers (if they have ridges on the jaws, cover with masking tape to avoid marring the wire)
wire cutter or flush cutter
sand paper - 180 or 220 grit, emory board or small metal file
Supplies:
Silver tube beads (about 3/8 inch - 4 mm long.  I had these from my grandmother... glass bugle beads should work too)
18 gauge wire for the ring base - copper, brass, silver etc.
24 - 26 gauge wire for wrapping and attaching the tube beads
You can use all the same kind of wire, or different colored wires for a multi-toned ring.
You will be working with potentially sharp wire and tools, so use CAUTION and be SAFE.
Step 1Form the ring base
Form the ring base
Decide what size you want your ring to be.  If you have one, use a ring sizer.
Otherwise, you can use a strip of cardstock  or thick paper to approximate your ring size.  Wrap strip around your finger so it is snug, but not tight - it should just rest on the skin, not compress the flesh of your finger.  Fold the paper at the right size.  Add a few mm or 1/8 inch to allow space for the wire wrapping.  Find a dowel, tube or pipe the same size to use as a ring mandrel.  You cand make a dowel 'fatter' by wrapping layers of paper around it and taping everything together when you get the desired size.
SAFETY TIP:  Hold onto the extra part of the wire before you cut it, then it will not go flying across the room or into your eye.
1.  Cut 8 inches of 18 gauge wire for the ring base and
24 inches (2 feet) of 24 or 26 gauge wire (You can use 22 gauge if your wire is dead soft, but it gives a more chunky look to the ring)
2. Wrap wire 2 and a half times around your mandrel or dowel.  Pull the loops tightly against each other.
3. Use one end of the 24 ga. wire to wrap about 1/2 inch of tight coils to secure the overlapping 3 wires on the bottom of the ring (8-10 loops).
4. Trim one end of the 18 ga. wire close the securing coils.  Sand or file the end smooth.  Continue wrapping 24 ga. coils over the filed end of the wire and continue 3-5 coils around the two remaing loops of the ring base.
5.  Spread the two ring coils apart at the top of the ring (Directly opposite the coils securing the ring base).
6.  Wrap 24 ga. wire once or twice around one of the 18 ga. ring loops, 1/4 inch up the side of the ring.
Now you are ready to lace on your zig zagging tube beads.
1 comment
Jul 21, 2011. 3:47 PMkools421 says:
This looks really hard. Can you make some for me please?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
42
Author:wombatmorrison
