Matereals
1 16 - 20 ga sheet metal
2 1/4" x 4" steel pipe
1 1/4" pipe connector
2 Pulleys
2 Rollerblade/skate board bearings
2 3/4" rubber 'o' rings
2 3/16 x 1 1/4" bolts
4 3/16" nuts
2 3/16" lock washers
1 Tube of grease
Tools
Drill (1/4" drill bit*)
3/16 drill bit
Dremel (small sanding attachment)*
Crecent Wrench or Pliers
Metal shears/ Tin snips
Hack saw
Permanent marker
Ruler
* You will not need this if you have a 1/2 " drill bit, except for some fine tuning. This is just what I used.
Remove these ads by
Signing UpStep 1Preping Matereals
Next you must outline your frame design onto a piece of sheet metal. I used a somewhat triangular pattern. Its important to have accurate measurements because balance is key for a device such as this. My measurements were 4.5" x 1.5 " x 2 1/4 x 1" x 2 1/4 x 1.5 . I did this for both pieces, and measured the spots where I would drill holes for the axels and handels to go. I placed my axel holes; down 3/4" from the top. From left to the center of the axel hole is 1 1/8 " and the space to the next axel hole is 2 3/8 inches which leaves you with 1 1/8" to the right side of the frame.
The hole for the handel I measured from the top which was 4.5" across. I marked my 2 1/4" point and drew a line down to the bottom area which crossed at 1/2". I measured 1/2 " up the line I had drawn and marked the center of where I would drill the hole for the handels. After you drill the 1/2" hole for the handel, you will have about 1/4" left between the bottom of the handel and the bottom of the frame.
Last thing you need to prep is the pulley wheels. All you need to do is add a generous amount of grease to the center. The grease will reduce the friction of the wheel rubbing against the threads of the bolt. I used white lithium grease on mine, and it seems to work well.
Add Comment
