ZIPPO TRICK: the Squeeze
Published
Introduction: ZIPPO TRICK: the Squeeze
About: I will mainly be posting instructables on Zippo's and regular lighters..
If you find this helpful at all please favourite.... I'd you have any questions about the trick don't be afraid to comment
Step 1: Gripping
Place the lighter side ways on your index and middle finger....... Make sure the hinge is facing up....... Grip the cap with your thumb and index finger firmly.... So that the lighter doesn't come flying out
Step 2: Flip
While gripping the cap make sure that the end of the lighter is pushed against the bottom part of your index finger..... Look at picture for better explanation....... From there push on the bottom half of the cap with your middle finger.... If you do this correctly it should rotate the lighter through the bottom of the hole between your fingers and through the top....... Doing this fast enough opens the lighter.....
Step 3: Light
No that the lighter is flipped open... Slide it back into your hand and light it using your thumb..... CONGRADULATIONS you can now do the trick.... If you found this helpful at all please favourite and comment.... Also if you have any QUESTIONS!!!!!
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    • Pets Challenge
      Pets Challenge
