Zombie Apocolypse Survival Kit Shadowbox
31,071
198
27
Published
Introduction: Zombie Apocolypse Survival Kit Shadowbox
About: I think my interests tell a lot about me, I'm a multimedia artist which means I work in whatever medium grabs my attention, paint on canvas is very relaxing and acrylic paint can be mixed with paper to make ...
ZOMBIES ZOMBIES every where !  Zombies seem to be the latest fad, whither you believe in them or not there are television shows, movies, games and evn clubs that do Zombie walks.
 A couple of months ago I posted a Zombie Survival Kit my son and his father in law created for a friend https://www.instructables.com/id/Zombie-Survival-Kit/  between the time spent and the actual items inside this box would be prohibitively expensive to recreate and attempt to sell so I set about building a less involved but I hope still pretty cool version. I've already started working on another because this one was fun but it is kind of small
Step 1: What's Inside
This box is kind of small so I was limited in what I could fit inside, there is a zombie apocalypse survival guide, a 3 step survival sign, a sawed off shot gun, shotgun shells, sticks of dynamite and a large knife
Step 2: The Box
 I picked up a 12x15x2" shadow box at Micheal's craft store, I removed the lid, lightly sanded then double primed the box and then painted it as shown using red and black craft paints and a bright green artist paint with some silver iridescent paint mixed in. Using white glue with a little of the green and iridescent paint I attached the help sign to the back of the box.
 the palette I used for both the paints and glue is a piece of lexan plastic I found while curb mining, it was one of about 2 dozen pieces of various sizes
Step 3: Ammo Box
playing again in paint shop I created a box for zombie killer shotgun ammo. I know I need a better printer because even with new ink cartridges the prints weren't that great but at least the boxes came in handy (recycle) and since the printer was a curb rescue I really can't complain.
I carefully pulled the box apart, turned it inside out then reassembled it ( I used the glue bottle as a weight until it dried) and covered it with the sheet of paper with the ammo print
Step 4: The Book
I played around in paint shop with some zombie images and different fonts until I got something I liked. then I printed it out and folded the paper in half, using some rejected versions I folded them in half until I had a decent bulk. A regular sewing needle with some thread passed threw the fold a few time held it all together whil I cut the "book" down to size
Step 5: Dynamite
my bad printer actually worked well for this since the color looks like faded red and black. I made the page in paint shop pro then printed it out, I went and searched my possibilium pile and found some 1/2" pvc pipe I had found at some point and cut it to length and then glued the paper on using white craft glue
Step 6: The Gun
the transformation of this toy makes it TOTALLY ILLEGAL and it could get you in serious trouble. It seems that everytime I do one of these conversions I forget to take pictures !
I found this toy while out curb mining https://www.instructables.com/id/Mining-for-suburban-gold/ so it's another recycled piece, the "shotgun shells" were found at a different time but they are also curb rescues.
I removed part of the stock, using my dremel with a cut off wheel, leaving just a pistol like grip.  I then sanded down some decorations that were on the side and using my dremel still with the cut off wheel attached I added some graining to the wood along with cracks and gouges. I painted the "wood" with burnt umber and indian red artist acrylics and then used a thinned black to give it a wash. I painted the black and then used a wash of burnt sienna, yellow ocher and black to "rust" the barrel.  There are several other pictures on my other "ible" if your interested https://www.instructables.com/id/Hacking-toy-firearms-for-Halloween-costume/step2/saw-it-off/
Step 7: Assembly
I used a hotglue gun to attach everything inside the box, you can see that the "ammo" box kind of floats, I wanted it to be seen in the corner of the glass and since the cover will be glued shut I just placed it were it worked best, the same is true of the "dynamite" I used a small cut off piece of pvc to position the 2 sticks where they would be best seen
Step 8: Finished
I reattached the hinges for the lid and once I get the glass cleaned and polished I'll glue the lid down
    • Spotless Contest
      Spotless Contest
    • Make it Move Contest
    27 Comments
    jeez you guys do not ever do a fact check. Zombies are real but the cure is salt
    thank you for your very poignant and obvious observation
    Nice survival kit. One thing I'll suggest is that you probably don't want to use dynamite against zombies. If their blood splatters on you, it could lead to an infection.
    well... if you're close enough for their blood to splatter on you, you're probably to close to use the dynamite............. thanks for commenting
    I sent this on Dec 21, but it must have changed the date to San Francisco time.
    that sounds cool, hope you do an instructable on it
    Yes, I will. I already have a lot of pictures of the building process for an instructable. I'm having a little bit of trouble creating a realistic action for the triggers, I want them to have some resistance and then a sort of click like a real trigger pull. I also have to devise a mechanism for the barrels to be easily locked and unlocked so they can flip open realistically. I would replicate every internal part of the real gun if I could, but I don't have the tools or materials for that.
    This is really cool! Always see the Vampire kits, great idea for a Zombie one.
    You can never be complacent when there are zombies afoot. Turn you back on one and they’ll eat your brain in a wink of an eye.
    http://www.zombielandrules.com/
    1. "Cardio"
    2. "Double tap”
    3. "Beware of bathrooms"
    4. "Seatbelts"
    6. "Cast iron skillet"
    7. "Travel light"
    8. "Get a kickass partner"
    12. "Bounty paper towels"
    15. "Bowling Ball"
    17. "Don't be a hero."
    18. "Limber up"
    21. "Avoid strip clubs"
    22. "When in doubt, know your way out"
    29. "The buddy system"
    31. "Check the back seat"
    32. "Enjoy the little things"
    33. "Swiss army knife"
    34. "Clean socks"
    48. "Hygiene"
    49. "Always have backup"
    This is great! This will be the next gift I make for my boyfriend. He has a survival guide/plan for the (inevitable) zombie apocalypse.
    Thank you, if you make one please share it
    a samurai sword would be great but I'd need a bigger box !
    My brother has always wanted one of these since he saw it here: Zombie Survival Kit.
    He's been asking me to make one, but I couldn't even think of where to start before now.  Thanks!
    the 1st one we did had a lot of time put in the box itself and inside things like the pistol was a real steel pellet pistol, a marine kbar knife, a real (defused) grenade even the ammo was real but had the powder removed. This one is a lot cheaper but of course it depends on what you put in it, I had the option of a realistic looking pellet gun but the $30 price was prohibitive. Make your brother one.. lets see what you come up with !
    Selling is the idea ! What to price it at is the question ! thanks for the enthusiasim
