3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Zombie Costume in 90 Minutes
Step 230 Minute Destruction Fest
Tools: Hand Hoe
Pants:
First take the pants and bash it unevenly all over the place with the hoe with moderate strength. Make sure it pierces through, but also make sure the holes are all small to medium in size. About 25% of the pant should be covered in holes.
Randomly pick some of the holes and tear a little bit with your hands.
Choose one of the kneecaps of the pants and chop a "X" shape making sure not to connect each of the tear. Then use your hand to tear the knee area apart to whatever size you want. Make sure it's hand torn after the initial tearing for the effect of struggle.
On the opposite leg, go to the ankle area and hoe it up and rip a hole the same way you ripped a hole in the knee area.
(Don't forget the back of the pants)
Shirt:
Rip the side of the pocket down.
(Optional: Heart area - smash a small "X", rip it slightly, and char it with a lighter to make a bullet hole effect.)
Use the hoe and create holes in 5 to 10% of the shirt (front and back just in case you ever take off your lab coat).
Pick two or three of the holes and tear them a little bit with your hands.
Pick one shoulder and weaken the support using the hoe. Make sure to rip it using your hands and not completely with your hoe. Tear it down about 6 inches.
Pick opposite arm and using the "X" technique create a hole in the lower arm region.
Lab Coat:
Rip one or both of the pockets.
(Optional: Heart area - above the area of the shirt's bullet hole, do the bullet hole for the lab coat)
Shoulder (depending on which side you picked earlier) should be ripped in the same way.
Arm (depending on which side you picked earlier) should also be ripped in the same way.
Cover about 25 to 45 % of the lab coat with small and medium sized holes with a few wider hand torn ones.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:AKFortySheep
