Zombie Truffles? by kristylynn84
Contest WinnerFeatured
Okay, I fell in love with Zombies at the time the movie Fido came out.  I'm also a researcher for the ZRS and my husband is the one who got me into these monsters.  Those are the reasons behind these Zombie Truffles!  There was a part in Fido, where Mr. Theopolis (the neighbor) comes over and says "Zombie Troubles?" and that's where my chocolate brains got their name!  I put different things in my candy, and you can always change it up to best fit your taste buds!
** This is to celebrate May, which is Zombie Awareness Month!  :)
** Most important part to remember, if you use this to gift, or to display, you want to think about your presentation.  You want the end product to fit the mood that you're going for.  :)  The rest should be easy!
** Here is a message from the CDC on the Zombie preparedness topic, and my chocolate video below.  :)
------------------------------ My favorite scene from Fido !! ---------------------------
http://youtu.be/RNurrFsufcA
Step 1: Stuff You Need!
*White chocolate melts (wilton)
*Black food coloring
*Some stuff for blood
*Brain mold (candy or ice)
*Stuff to put in your candy
*Ziploc bags
*A way to present end product
*Coffee cup to melt chocolate in microwave
*Spoons, etc.
Step 2: Prep!
If you want to put things into the candy, make sure to have them ready, in small enough sizes to fit into the mold when it's ready.  Have your chocolate ready to melt, arrange everything nicely so that you aren't scrambling at the last minute and think about what you want to do.  :)  Be ready because you need to have all decisions made before you melt the chocolate.
Step 3: How to make bloods!
Okay, I did two kinds of blood at once.  Basically, I wanted something thick and disgusting.  I took from my cake supplies and mixed a crazy, nasty bloody mess out of the things you see in the photo.  You can always choose to make yours differently or use other ingredients.  He tasted the bloody brains and said they were good.  That makes it a success for me.  :)
You can go one of two ways...taste and "feel" or...accuracy.  I've seen red syrup and we all know that it represents blood but doesn't look like it.  These things that I used, they really added up to the look.  Maybe not the sprinkles...but I had to throw something pretty in there. haha.  And the bonus is that it passed the taste-test.
After I mixed the bloody concoction, I scooped it with a spoon into a baggie for piping into the brains when the chocolate was melted.  The container was still full of blood residue so I added some Mirin or rice wine and it held the consistency for the drippy blood that I wanted to drizzle with.  PERFECT!  You can use some other alcohol if you want.  You won't really be tasting it much, anyways.  It's just to decorate with.  :)  Then I poured my drippy blood into a ziploc to use it as the last step.  (Drizzle each brain lightly.)
Step 4: Melt Chocolate & Add Color!
Okay, I may be one of the only people who use the microwave.  But it's easy.  I put the chocolate melts into the coffee cup, about 3/4 full.  Put it in the microwave and wait 20-30 seconds, pull it out and stir them.  They won't be melted, but you want to keep them moving.  Put it in again for another 15 seconds or so, pull them out... they should start to lose their shape.  You will see the edges melting away into blobs.  At this point, you want to mix really well.  Toss them around in the cup, get them moving.  If your chocolate starts to melt even more and you can't see the shapes anymore, don't put it back in the microwave.
But if they aren't melting, put them back in.  Another 10-15 seconds and pull them out, mix again, help them melt by moving them around and constantly mixing.  This will make your chocolate super smooth, not burnt and ready to color!
Get TINY TINY TINY drops of the black coloring and put them in one at a time, mix into the chocolate really well.  Keep adding TINY bits of color until you get the result you want.  It's important not to make charcoal brains!  :)
Step 5: Pouring Grey Matter!
Okay, I just used a spoon.  Once it was to the color I desired, I got a spoon full of chocolate, dropped a small dollop into the brain cavity and poked it down with the tip of the spoon.  You want to put less chocolate if you want to put things inside of your candy.  Just remember to make room, so that you can seal the top of it.  ( Put 1/4 full of chocolate, then filling, then top it off with another small dollop.  Use your spoon to smooth out the peak and you're done!
Fillings I used:  blood mixture, heath toffee crunchy candy stuff, marshmallows, sugared jelly candy.
Step 6: Fridge!
Put your chocolates, carefully, onto a flat surface into your fridge and be patient.  If you take them out too early, the tops will have set, but the bottom of the mold won't be set.  One way is to feel the tips of the brains to see if they are cold from the outside of the mold.
After 10-20 minutes, they should be done.  Mine just popped out really easily and I didn't use any spray in the mold or anything.  Rinse and clean out any leftover brain chunks in the mold, that way your next set gets the same impressions.
*TIP* You can change the color of your chocolate each time you mold a new set, and put different fillings in them so that you know what color has what item inside.  Also, a coffee cup of chocolate pretty much takes up the whole mold, so it's easy to cycle them through, clean stuff up, let them chill and begin again.
Step 7: Brain Sculpt!
Everyone makes mistakes!  I over pour, you over-pour...that's life.  :)  So what you do, is take a knife that is too sharp to be using this close to your fingertips and try not to cut yourself open like I did.  4 times.  :)
Basically, you scrape the edges and the chocolate will shave off.  You can do this to the flat bottoms of the brains too, if they aren't level and you want them to be.  When you clean up your edges, you just need to run your fingertip around the edge and it will round and smooth it out with your natural body heat.  It's cool.  :)
Step 8: Presentation!
Ways to present ---
Gift, for a friend, loved one, surprise, in a lunch, at a party, etc.
Think about whether you just want to throw it in something, or if you want to make it elaborate, or if you need a platter, maybe you want a gift box...you can do this any way you want.  If it were for a party, I would probably make it up on a silver platter with TINY round shreds of lettuce with a brain on top of each piece and blood drizzled atop each of them.
For a lunch, just throw them into a ziploc with some drizzled blood and zip it up.
My idea was to put them into a Valentines Candy box.  I used cut up napkins to put under each brain, carefully.  If you use tissue, napkins, soft materials like this, make sure that you do it close to the presentation time because the napkins will absorb the blood and look sloppy.  Another great idea is fabric.  White fabric, cut into tiny pieces.  That would be really cool.  :)  Strong, and visually creepy.
Most importantly, enjoy!  Grey chocolate will look the most accurate, but if you don't like white chocolate, do them in milk chocolate, or dark, or whatever you'd like.  I made these for the accuracy and gave them to my husband.  I don't like white chocolate and these brains look gross, so it just adds to the effect for me. LOL.
Thanks for reading, happy Zombie Awareness Month!
h8864 says: Jun 25, 2012. 10:40 AM
what is the zrs
effiesque says: Feb 1, 2012. 8:18 PM
Absolutely Beautiful! Im off to find a brain mold!
Now i hate white chocolate but you could paint the molds with the chocolate until theres a decent layer of the 'green' chocolate... then proceed to fill the rest with Dark chocolate! that way you get the chocolate you like and it still looks like a brain!
:) It works, i've done it before on christmas molds with different colours
Thanks so much!
Gracie Ann says: May 22, 2011. 9:39 AM
where did you get the brain mold??
kristylynn84 (author) says: May 22, 2011. 3:11 PM
it's Wilton brand, silicone, i think... and i got it on clearance around halloween. maybe walmart or michaels? i forgot. :( and i believe it's an ice mold. :)
shimmeringfae says: Jan 13, 2012. 7:28 PM
Unfortunately Wilton has discontinued that mold now, it may be found on ebay or something similar by another company. I bought a silicon skull ice cube mold at the dollar tree around halloween this year, not quite the same but similar.
izella says: Sep 7, 2011. 1:26 PM
Me too! These are delish. Uh, you do need to change your search tags because the one about Keanu Reeves is mean and a little sick.
tchitwood says: May 25, 2011. 3:58 PM
Awesome! :) Love Zombies and Fido is one of my favorite Zombie flicks. Great job and great idea! Have to make these! Wondering if I could just coat the moulds in the chocolate and then put them together with a cake ball in the middle to make brain cake balls. Mmmm mmmm would have been great to serve with my zombie cake! Now to try to carve out some time to make these... Can't wait for Halloween to try them. Besides, any day of the year is a great day for zombies!
kristylynn84 (author) says: May 25, 2011. 11:54 PM
i say that you host a scary movie weekend and make those cake brains! :D just coat them with a good layer of chocolate so it won't break. and blood to dip? hahah.
SlinkingFerret says: May 21, 2011. 1:10 PM
All the chocolates are yummy, but the toffee brains are my favorite! going to get another right now!
SHIFT! says: May 19, 2011. 11:48 AM
This is a very well documented 'ible and a very clever idea, but do you think you could perhaps cut down on the number of times you use "Zombie". It just becomes a tad repetitive to read after a while.
Alternatives: the Undead, Lurkers, Infectees, Corpsenators, the Afflicted, the Unconsecrated, Living Impaired, or Keanu Reeves.
Nelson_Yepez says: May 21, 2011. 12:01 PM
zombie word was used only 5 times in the entire instructable... is that repetitive?
loveisweakness says: May 21, 2011. 3:32 AM
Be fair, Keanu isn't a zombie, he's just an immortal demon. Although I will agree his acting skills are on par with zombies.
kristylynn84 (author) says: May 21, 2011. 1:10 PM
are you guys talking about the movie Constantine? lol
kristylynn84 (author) says: May 19, 2011. 3:53 PM
I totally know where you're coming from, I like to mix things up when I blog and write. But, I am a purist, and I know that sounds uber nerdy. I love your list of alternatives but those words don't mean the zed-word to me, lol. I have a word-thing. I still heart you, SHIFT and want to thank you for the compliment! And apologies for the verbiage.
Gergohogbeido says: May 21, 2011. 4:26 AM
good :)
Biggsy says: May 20, 2011. 3:25 AM
I BRAAAAAAIIIINNNNSSSS this project!
flyingpuppy says: May 19, 2011. 8:53 PM
You're sick. I love it! Brain food!
moxiepurple says: May 19, 2011. 7:24 PM
Those are so cool! Mmmm chocolate brainssss!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
