Zune Disassembled
430
4
Posted
Introduction: Zune Disassembled
Microsoft zune disassembly
Step 1: Tools
Small Phillips screw driver
Pry tool- I used slypry
Also use a little magnet to hold all small screws
And a magnetizer demagnetizer tool helps to mag your tools
Step 2: Remove Bottom Screws
With small pry tool pop out the plastic cover (on the bottom around the connector) hiding two screws
Step 3: Pop Open Case
After the two screws are out use pry tool around the seam. Once pop work around until fully separated
Step 4: Internal Screws and Connections
There are four screws that hold HDD to board and front cover
With pry tool pry up on the brown part of the connection with that up the strip should come free. Bend the cooper wire up so you can get HDD out Flip over HDD with pry tool pry up the black clip that holds its band
Small Phillips screwdriver
Step 5: HDD
Peel black sticker and pop out HDD
Step 6: More Screws
Remove screws to get cover off
And your done
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
