Introduction: Zwift Ambilight and Heart Rate Zone Smartbulb Lamp
About: I am always young, because i feel so!
Here we build a little BIG improvement for Zwift.
You have at the end a ambilight for more riding fun in the dark.
And you have a lamp (Yeelight) for your heart rate zones.
I use here 2 Raspberry PI, if you want only the Yeelight you need only 1 PI if you want the complete Show you need 2 PI's
Lets start with some stuff:
Step 1: Hardware
You need for the Ambilight this Tutorial:
http://awesomepi.com/diy-breath-taking-ambilight-f...
I dont write a new one, because this is great. But do ONLY the Hardware setting and not the Software
I give you a ready IMAGE for the Software.
There are links to buy, but you can also buy some parts on www.reichelt.de
I buy my cable and E27 Socket from there also the powersupply:
https://www.reichelt.de/NKES-150-SW/3/index.html?A...
https://www.reichelt.de/FASSUNG-E27W/3/index.html?...
For the power supply you can use
https://www.reichelt.de/Schaltnetzteile-bis-150-W/...
or better a closed one:
https://www.reichelt.de/Netzteile-Festspannung/MW-...
They have also the cable to solder and cable bridges for the raspberry:
https://www.reichelt.de/Kupferlitze-isoliert/2/ind...
https://www.reichelt.de/Entwicklerboard-Zubehoer/D...
And the PI Bundle you need:
https://www.reichelt.de/Einplatinen-Computer/RASP-...
The Yeelight i bought from ebay.
Step 2: Software for Ambilight TV
Here is a premade image for your raspberry with a Kodi openelec image:
http://www.quakeit.de/openelec_kodi_ambilight_rpi3...
and a RGB Testsequence:
http://www.quakeit.de/RGBTestSequence.zip
Just transfer the Image with Diskimager if you use Windows
If you use Windows and you have openelec connectd to your network you can browse the Folders
with windows:
Put in Folder Configfiles this hyperion Config:
http://www.quakeit.de/hyperion.config.json
then restart your openelec
If you make all right a effect is showing after booting
Put the RGB Test Sequence in Videos and enjoy the show.
Lets jump to the yeelight
Step 3: Software for Yeelight on the Other PI
It is always good to have more then 1 PI :)
On the 2. we install our yeelight and the Zwift connection.
The Reason is, that you cannot install stuff on openelec like GIT etc.
Just install an Image from www.raspberry.org
then install GIT
sudo apt-get install git
after that follow here, i have forked a git to make it easier:
https://github.com/Landixus/ZWIFT_SMART_FAN
I choose this, because you can also control a FAN, thanks goes to DKanjuh for it!
For controlling the yeelight you need to activate the LAN-Control of your yeelight, see image.
Follow the Installation instruction there, if you want to control a fan, make your hardware and settings.
If you just want the yeelight, open the ZwiftYeelight_01.py with
sudo nano ZwiftYeelight_01.py and change lines
bulb = Bulb("192.168.0.76", auto_on=True, effect="smooth", duration=timeout) #IP Address of your bulb have to be replaced
#replace your Heart Rate Zone hereHerzfrequenz = 0Herzschwelle1 = 70Herzschwelle2 = 90Herzschwelle3 = 100
cli = Client('YourMailAdress', 'YourPassword')
you can adjust the colors here:
bulb.set_rgb(0, 255, 0)
If you want to add zones you can add Herzschwelle4, Herzschwelle5 etc....
then you add:
if Herzfrequenz >= Herzschwelle4: bulb.set_rgb(255, 0, 0) time.sleep(1)
and so on. I work on the script to make more zones and easier to handle and improvements.
If ready, you need to start Zwift and go into a drive, dont forget to put the chest strap for heart rate on.
The start your yeelight script with:
sudo python ZwiftYeelight_01.py
If you have some missing libraries you need to install them with pip:
for yeelight do
pip install yeelight
or
sudo pip install yeelight
Step 4: Trouble Shooting
Long cables are always bad, try to use short cables. The HDMI Signal should not go throug a cable longer
then 5 Meters. Otherwise put the HDMI Splitter near the TV.
Before you cut the Stripes make a TEST on the floor... Is it all right connected?
Poor Power Supply, dont use your mobile charger! Use a stable Powersupply with enough power!
I had problems with the Edge Connector Clips for the stripes, where you dont need to solder.
Solder it! If you cant, ask a friend, the stripes are easy for every hobbiest to solder.
Clean your TV before you add the Stripe.
You deal with Real Power, so turn it off when you working on the powersupplies!
Reminder for me! Add more images :)
More images added
