A Little Round Swing
Published
Introduction: A Little Round Swing
With these instruction you can build your own swing in a matter of hours and that is easily to take with you.
Step 1: The Materials You Need
  • a peace of wood from a thickness of 13mm;
  • a strong rope (you can choose the lenght);
  • a knife to cut the robe, (if you need one);
  • a toolbox saw;
  • a Drill
  • some paint
Step 2: Making the Seat
First of all you need to have a cirkel of wood the diameter doesn't matter.
The second thing you have to make are 4 holes in the seat for the peaces of rope to fit through
the third thing you have to make at each quarter of the cirkel are 4 gaps you can saw that out. The reason you need those four gaps is because if you take your swing with you, you can role the rope in those four caps so you need to have one hand to transport the swing
Step 3: Making the Ropeholder
Saw a peace of wood and round off the corners a bit;
Then you have to drill 4 holes again in a triangle ( drill holes that are a little big bigger in diameter than your rope).
Step 4: Making the Height Regulator
First you take a little block of wood you can choose what shape
Then at the top of the block you have to drill a diagonal hole throw the block, now you have to drill an other hole horizontal off the upper side (also here make a hole that is a little big bigger in diameter than your rope).
At the drawing you can see how the rope must be insurted.
Step 5: Paint Your Swing
So if you want you can give your swing a color
Step 6: Putting the Ropes in the Holes
On the picture you can see how you need to insert your robe in the swing
  1. first take the rope and put it in your height regulator under your swing en pul it al through. take your swing a throw it over something you want to swing on
  2. put your robe in the second hole
  3. punt your robe in the thirt hole at the bottom of your swing
  4. put your robe in the last hole not all the way and make a simpel not to secure the rope
you have also follow those stap to put your rope throw the ropeholder
Step 7: Testing the Swing
Here is a video how I test my swing
testing my swing
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
