Learn Perl Easy to Medium
2,948
13
8
Posted in TechnologySoftware
Introduction: Learn Perl Easy to Medium
Perl is a text based scripting languge that has it's advantages and disadvantages,this tutorial will give you an overview of the basics and the functions that most scripters (AKA;programers)
would use. LETS GET STARTED! (for windows operators only)
I am assuming that you have worked with a hello world program before or/and worked with a interpeter.
when scripting in perl you have to change your PATH,
but if you dont want to do this, use perl express (shown below).
*note plese rate and comment this instructable
Step 1: The Materials
1.a perl interpeter (google it!)
2.if you want, perl express (google it!)
3.also, if you want , modules (google perl modules for some)
install the modules in the "lib" folder in your perl interpeter's directory
Step 2: Your First Program
okay lets make a simple program,
copy and paste this #!/usr/bin/perl
print "hello world";
that is the simplest program you can make, if you want to add to it a little, type #!/usr/bin/perl
print "hello \n world";
you made your first program! , \n is to make a new line
now lets get a little more advanced
Step 3: Variables
now there are three types of variables,
1.scalers (holds one strip of data) (( $scaler name = value;)
2.arrays (holds multiple strips of data)
((@array name = (values);)
3.hashes %hashname = (value => other value , value => other value #put as many of theses as you want )
Step 4: Getting More Advanced
lets make scripts that print the values of variables,
type these scripts! (you dont have to type the comments , comments are noted with a #)
1. #!/usr/bin/perl
$variablename = 5;
print "$variablename";
2. #!/usr/bin/perl
@arrayname =(value , value2);
#remember , you must refer to arrays as scalars example (the indexe are in order starting at zero
print "$arrayname{0}\n"; #print value
print "$arrayname{1}\n"; #print value2
note:for the code above the { and the } symbols are actully square brackets
3. #!/usr/bin/perl
my %hash = ( v => value , v2 => value2);
print $hash{v};
now lets learn another use for scalers,
type or copy and paste this code
#!/usr/bin/perl
$scalername = <STDIN>;
print $scalername;
type in anything you want
when using command prompt but if you're using perl express,
click on std.input then click on the i/o symbol
now lets find some more uses for variables
Step 5: Another Use and Looping
#!/usr/bin/perl
if ($scalername =~ m/bill clinton/)
print "its clinton alright!";
okay, you might be asking "what does the if do?"
scroll down and you will see!
in the if statment perl behaves the following way,perl asks "does $scalername contain bill clinton?"
here is another function that is also useful
the while function example:
#!/usr/bin/perl
$a = 1;
while ($a==1) # == is for numbers only
print "a = 1";
else { print "a does not equal 1"; }
the next step will talk about boolean functions
Step 6: Boolean
boolean is for numbers only!
heres some functions
== , equals
!= , not equal
< , greater than
> , less than
(*) , multiply note:in multiply theres no ()'s
+ , add
Step 7: Putting It Together
copy and paste this code ,
#!/usr/bin/perl
$operation = <STDIN>;
if ($operation =~ m/multiply/)
print "enter a number:\n";
$a = <STDIN>;
print "enter a number to multiply $a:\n";
$b = <STDIN>;
$c = $a * $b;
print "$a multiplyed by $b = $c\n";
if ($operation =~ m/add/)
$a = <STDIN>;
print "enter a number to add to $a:\n";
$b = <STDIN>;
$c = $a + $b;
print "$a added to $b = $c\n";
Step 8: Finished!
when you write your own programs you might want to add this function in your code
use warnings;
okay youre done!
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    8 Comments
    Get Perl for dummies. Way better then this.
    Which interpreter do you use? Any time I open a script in active perl it closes almost immediately. I can just barely see it say "hello world!".
    dont open it directly from active perl open the script from a command prompt WITH active perl.If you dont want to do this use perl express.To do it with the prompt change your path to where active perl is.Do this by entering path directory here.Please tell me if this solves your problem if it dosent I will be happy to help.
    I opened it with perl express and it worked, thank you for helping!
    youthink this is complicated? , try java
    what looks complicated ? ,the script in the picture or the tut?
