you will need:
1 Blucky skeleton
1 can great foam
a dremel or razor knife
masking tape
2 pairs of pantyhose
1 tub carpet adhesive *edited to add* BE SURE you get the HENRY brand of carpet adhesive. no other kind will dry overnight! HENRY is available at Lowes for $13.00 a gallon.
hair (either real or fake)
wood stain
paint brush
rubber gloves
something to use as a drop cloth
Remove these ads by
Signing UpStep 1Fix the defective joints if needed
so the 1st order of business is to fix the defective joints. i decided to disassemble it, and fill the bones with spray foam insulation. then re-assemble. hoping this will meld the pieces together well, and add a little weight. nothing looks faker than a Blucky blowing in the wind!
it is laid out on the counter at the shop. the customers kept giving me strange looks.. can't imagine why! so i figure the excess that is oozing out can easily be trimmed away. i do have a back-up plan in case the spray foam won't hold firmly enough. it involves hot glue. hopefully it won't come to that though... the panty hose i plan on applying next should bind things well.
18
comments
Add Comment
Kiteman
says:
PaHalloweenFreak
says:
Spl1nt3rC3ll
says:
Add Comment
