3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
a little brown egg in Maine: terra cotta smoker
My fiance has mad cooking skills, but he doesn't have a smoker. I wanted to make him one, but I also wanted it to be good looking in my backyard. Without the funds for a Big Green Egg, I googled "terra cotta smoker", and hit a jackpot. But no instructable! I wanted to make one of those too, so I'd found a twofer.
My favorite site was created by a guy from Atlanta who documented many of his steps, and cooking on it, too. If this instructable can be as helpful to someone else as his site was to me, then I'll be pleased.
Step 1Assembling the parts
The first step (after prowling the web) was assembling the kit of parts. Here they are, arrayed on my front porch:
on the bottom step, the item I was most worried about finding, the single burner hot plate. The last time I saw something like that , it was an illegal object in my dorm room, in a time before the web. (Yes, I am OLD!) Most web authors claimed I'd need 1000 watts. I found a couple in on-line hardware stores and at Amazon, but for $20 plus shipping. (lower wattage ones were about $14) Since my target total expenditure is $60, and I found a commercial smoker for $38.40 at Home Depot, that was outta budget. But a local remainders store (Big Lots!) had one for $7.99, and another local low-rent chain (Reny's) had one for $9.99. This is a Maine adventure. I figured I needed to have the burner in hand to know the size of the base of the cooker, hoping to find a lot of variety in pots and other enclosures. So I started by spending 8 bucks at Big Lots! (yes, the ! is part of the name)
In the middle, the cookery gear. I found a small saucepan for $2.99 at Christmas Tree Shops a and a "grilling skillet" with folding handle for $3.99. Without their handles, these looked just about right for the wood chips container and the food grill. Also in the middle is a candy/frying thermometer with a range of 100°F - 450°F ($6.99 from a local hardware store), a rubber stopper to hold it ($1.50) and a rubber washer to block the bottom hole. This turned out to be unnecessary in that role but handy in another.
On the top, the pottery. an azalea pot ($9.99) will be the base, and a bulb bowl ($6.99) will be the top. Yes, I made sure the top fit inside the base at the garden store. These are standard unglazed terra cotta pots, roughly 30 cm at the top, with 2.5 cm holes in the bottoms. They might be a bit small for the kind of cooking Phil wants to do, but I'm going to start here and see how it all goes. Oh yeah, the cute little feet were $1.99 each, but who could resist them, and they make a space for the heater cord. So sweet.
65 comments
1-40 of 65next »
Apr 28, 2012. 5:38 AMNoVAN8iv says:
To seal the lid better, tear off a length of heavy-duty aluminum foil about equal to the circumference of your cooker, wad up into a "sausage" about 2 inches wide, mold it around the edge of the cooker, then squish the lid down, compressing the aluminum foil "gasket" so it fits snugly between the lid and cooker..
Aug 29, 2010. 7:26 AMpcorbett says:
I laughed hard when I saw you drilling that pot in your lap. Please don't take this the wrong way, it was funny to me at that moment but wouldn't be funny to you if you slip..........Dig? I'm sorry but it's still funny so please be carefull. pcorbett
Jan 28, 2010. 7:47 PMBerkana says:
 I recommend that you don't use non-stick or teflon coated pans; when they hit 460 degrees, they start breaking down and giving off toxic smoke. If you're smoking your food, the wood smoke may be obscuring any flavors from the breakdown of the teflon.
Jun 29, 2010. 11:50 PMdatgnat says:
This is true, & important to know about teflon, real barbequeing (as opposed to grilling) takes place attemps around 220-250 F...
Jun 30, 2010. 8:54 AMMomotaro37 says:
My understanding is that a small cast-iron skillet dedicated for the smoker is the way to go. Garage sales are a great place to find them.
Jun 30, 2010. 3:25 PMSpokehedz says:
Also suitable are disposable aluminum pie-pans which come in stacks of zillions and are cheap enough that I only re-use them about 4 times before i crumple them up and toss them in with the aluminum cans.
Jul 24, 2010. 9:27 AMzoof says:
I'm not so sure about disposable aluminum pans -- sandwiched between the heating element and the hardwood, the temperature can get pretty hot at the point of contact. My smoker burned through one of them before my brisket was done. I had to quickly find another solution.
Jul 24, 2010. 11:47 AMSpokehedz says:
That is strange... I have never had one come close to melting on me before. Then again, I use sawdust from a local furniture shop where they only use hardwoods, and not chunks of hard wood. You can get a cast iron skillet that will never melt, warp, chip, or crack from a local kitchen-supply store... Or that new-fangled world-wide-internets. Guaranteed to last more than your lifetime. http://www.google.com/products?q=cast%20iron%20skillet
Jun 30, 2010. 4:32 PMBerkana says:
You can also use those durable aluminum cake pans which have much thicker metal. They last longer, and the thick metal heats more evenly so all the wood in contact will smoke. With thin metal disposable aluminum pans, you get hot spots.
Jul 6, 2010. 6:48 AMrocktopotomus says:
I made one of these with some minor changes, as I could not find the bowl or grill thermo. I used a smaller pot for the top which sealed it very nicely and i used a temp probe with a brick to limit the amount of smoke that it let out. I have the 1000w hot plate from Wall-greens but my problem is that the thing got WAY TOO HOT. on the lowest setting the temperature kept increasing, so I'd have to unplug/ remove the top. Which of course released all the delicious smoke. and then wait for the temp to fall and then replug the hot plate in. I measured the temp with to different thermometers and they both gave the same reading. What can I do to keep it from getting to hot without creating a thermostat switch? do they sell wimpier hot plates? (<1000w)
Jul 3, 2010. 10:25 AMColonel K0rn says:
Haha, pots still in one piece :D. I guess if they weren't, then you'd have to buy another bottom pot, and then go over budget.
Jul 2, 2010. 5:29 AMakshay_chak says:
Thanks for a wonderful idea This kinda stuff is getting popular in India now...i mean the bar-be-que and stuff but the traditional earthen oven called the " TANDOOR" had always been a hot favourite . kinda reminds ne of that
Jul 1, 2010. 1:31 PMjkayner says:
why not just buy an "old smokey" charcoal grill (~$40) and the hotplate and put the hotplate inside the grill? Than you have the best of both worlds.
Jul 1, 2010. 6:57 AMjoelshults says:
We've been using one of these for years after we saw one on Good Eats. We've gone through a couple of hot plates but those are cheap to replace. This thing is great for chicken, ribs, a boston butt, or just about anything else that can handle a nice, slow smoking. We use a cheap hotplate from Walmart or someplace like that, and take the element out (it has a wire that unplugs inside there). Then run that wire through the hole that is already in the bottom of the pot and plug it back into the hotplate. Then you have all of the controls and parts that could be damaged by the heat, smoke, and meat juices safely outside of the smoker. We also use a little, rectangular cast iron pan set directly on top of the element to put the wood chips in.
Jul 1, 2010. 5:11 AMkmpres says:
I really like this instructable. I used to smoke beer-can chickens in an "all-in-one" smoker before we moved into a new house, but now I don't have space to store it so out it went with the trash on moving day. Pity, as my chickens were soooooo juicy and delicious! This idea could solve that problem as the "egg" could stay in our tiny yard and need not be stored at all. Your smoke generation might work a bit better if you use a cast iron smoke box designed for a kettle BBQ. They're about 4"x6"x1" and might just fit in the saucepan over your heating element. The cast iron will contain and retain the heat for quite a while giving you a more complete burn on the wood. You can even sprinkle a bit of beer in the saucepan from time to time for a lovely beer-steam effect. Love the dog! We have a white miniature poodle just like him. Best pet we've ever had.
Jul 1, 2010. 1:49 AMmrdiablo9 says:
Make a basic flour and water dough to make your seal.
Jun 30, 2010. 2:25 PMquiviran says:
Maybe you could make a gasket out of this stuff? http://sugru.com/
Jun 30, 2010. 3:18 PMSpokehedz says:
Sugru is not food safe--yet. They are working on it though.
Your best bet would be to get a smaller 'ash grate' from the hardware store which looks like a wee-little version of the grill grates that is intended for people who use chunk charcoal.
Also, you can scale up the pot and everything to quite large sizes and keep the same sized burner. I have quite a large pot where I can fit nearly 4 pork tenderloins with the same size hotplate and pan working just fine. I did have to add a small fan to make the smoke circulate a bit.
Jun 30, 2010. 1:17 PMjamina says:
Silicon is your food safe, heat resistant material.
Jun 27, 2010. 10:08 PMcoachmachado says:
What if you got a LARGER pot for the lid? This would make it easier to grab using pot holders, so no handles needed...
Jun 30, 2010. 11:24 AMBeeRich says:
Actually, a larger pot for the lid could also rest on the lip of the lower one, so that there is a better seal as well. The problem with this setup is that any condensate that forms on the lid will run down and to the outer lip on the top pot lip. But yes, I agree, this could be a better setup. Maybe construct some kind of clothes hanger hook system, mounted in the lip of the top pot lip for lifting. That way no mess from inside of lid, and a cool way to remove instantly.
Jun 30, 2010. 11:21 AMBeeRich says:
Try stuffing aluminum foil around the sides. In the commercially available smoking world (Weber Smokey Mountain, etc.), the forum guys use foil to seal up holes, lids, etc.
Jun 27, 2010. 5:27 PMrhbama13 says:
Thank you Alton Brown.
Jun 30, 2010. 8:51 AMMomotaro37 says:
I was thinking the exact same thing. This instructable is great, but Brown detailed everything a person would need on the show, and it can be found in "I'm Just Here For The Food" as well his website. And this isn't to take away from prof_jellis, excellent documentation and wonderful pics. This is something simple that just about anybody can pull off and when a person is done with smoking that meat, just repurpose the pots!
Jun 30, 2010. 6:11 AMGoddess of Travel says:
This is Alton Brown's smoker. He created it a few years ago in his show "Good Eats" Alton is a Culinary God.
Jun 29, 2010. 11:24 PMw0x0f says:
You can buy rubber stoppers with holes at places that sell wine-making supplies.
Jun 29, 2010. 7:16 PMspeedysk1 says:
I'm not certain, but do you like Guinness? ;) Great Instructable!
Jun 29, 2010. 6:54 PMgaffertape says:
To seal between the two pots, try rolling up a bunch of aluminium foil. It compresses under the weight of the top pot to make a reasonable seal. Its food safe, and it will handle the heat well. Thanks for the instructable.
Jun 27, 2010. 1:04 PMEricc815 says:
I will relate an extremely effective smoker built by a friend more than 30 years ago... take a tall school locker, line it with foil covered fiberglass HVAC insulation duct material, mount window screen over all the louvers, and install toaster oven in bottom... set bake thermostat and put small pan of wet wood chips into toaster oven, and thermometer thru wall near the top will give you accurate reading on your progress.
Jun 29, 2010. 4:16 PMdacker says:
Alton Brown did this in a junkyard episode sometime in the last 5-8 years. Maybe he stole the idea from your friend?! I'd probably sandblast the interior to remove the paint before heating it with my food inside.
Jun 29, 2010. 3:03 PMsc13nc3 says:
sounds tasty
Jun 29, 2010. 3:03 PMsrharvey says:
You typically find pots with matching drip trays that go under them, why not use a large trap as a lid on a larger/deeper pot to keep the weight of the lid down to a minimum. Make 2 or 3 more and then you can experiment with doing small batches of different woods / spices to make a whole feast at once. Loved the instructions.
Jun 29, 2010. 8:22 AMlej619 says:
interesting I wonder how well it would work with say.. charcoal? line the bottom with tin foil. put the charcoal on top of the tin foil you could still use the "grilling skillet ". as for the pan on the bottom you would not need it. just put the wood chips right in with the charcoal. Yes?? nice idea might just have to try it, maybe with the charcoal in stead tho.
Jun 29, 2010. 2:58 PMsrharvey says:
With charcoal you need to be able to regulate the air flow into the coals to regulate the heat. So drill some more holes and make some sort of damper.
Jun 29, 2010. 2:54 PMsrharvey says:
Why not push the rubber stopper through from the inside (like / \ vs \ / from the outside) that way it can't be pulled up out of the lid when lifting it? I think the risks of smashing your pot out weight the risk of loosing your stopper into the smoker.
Jun 29, 2010. 2:36 PMskidoggeruk says:
How about getting a bung from a local homebrew shop? Bungs for use with airstops already have a hole in them. Would that do?
Jun 29, 2010. 9:55 AMroamin_ronin says:
I think I know why you'renot getting smoke. Unlike the hotplates we used "back in the day" these have a safety chip in therm to keep them from overheating and catching fire.... However! you can just hack the case of the hotplate (some more) and extend that sensor out through that bottom hole. I saw it done either on here or another hack site, but I can't find it right now. Thanks for the inspiration! I'm thinking of making one this weekend, now to replace my old one.
Jun 28, 2010. 10:08 PMgothycdesigns says:
The smoker looks like a fun project....but the main props goto sticking a Guinness bottle in just about every shot. Loves me the Guinness a PROUD member of the 1759 society....lol. Thanks for sharing your project.
Jun 28, 2010. 2:20 PMM F says:
yes, it is a good idea to consider what materials give off toxic gasses. don't use glazed pots. unless you are sure they don't have lead or cadmium in the glaze. also don't use regular rubber stoppers. they give off toxic fumes. Ps: I use the heat elements out of the George Forman Grills. Lean Mean Grillin Machine. They are always available at thrift stores by the bunch. 2 to 10 dollars.
Jun 27, 2010. 1:39 PMceekay says:
Brilliant idea. Pretty too.
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:prof_jellis
