3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
a simple current amplifier
a amplifier of current . when we touch the wires it glows but without the circuit it will not glow brightly.you can make it on a pref board or without it i am making it with a pref board.
Step 1Things required
things required
things required-
1] 560 ohm resistor
2] NPN transisor
3] led
4]9v battery
5] battery snap
3 comments
Apr 30, 2011. 12:45 PMRockser11 says:
thanks, im building an ipod base out of a coke can and this will be very helpful
Mar 7, 2011. 4:56 PMsimmer65 says:
Be prepared to burn up your transistor if you try this circuit. My NPN transistors have a max Base-Emitter voltage (Vbe) of 6 volts. This circuit will send way too much current through the base.
If you want the LED to glow, remove the transistor and reduce the resistor. You will get about a 2v drop across the LED and 7v across the battery. To achieve a 50mA current (the brightness of an LED is determined by the current through it), use the equation V=IR or 7 = .05 * R......R=140 ohms.
Mar 7, 2011. 10:34 AMzazenergy says:
This is a good, simple experiment for an electronics enthusiast. Thanks for sharing!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:robot1398
None of your buisness
