3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
aNtistic design
aNtistic design
As much as I'd like to take full credit for this idea I can not (though i can claim most of it ).and being a person of ethics .I must give credit where credit is do .I was watching discovery channel one day and saw this professor (Walter R. Tschinkel if you'd like to google him) down in flordia .he was studying the tunneling habits of ants and would find abandoned nests and pour in molten zinc .then ,after waiting for it to cool ,he would dig it up and would end up with these amazing pieces that would spiral up to eight feet high
after having seen that months before I was laying in bed staring into the dark above me and I was hit with a flash .it's a feeling not easily described ,though it is how I get most of my ideas
so i set out to build a coffee table designed by ants .useing left over, unused, and unwated things .a jigsaw found in the trash, aluminum cans, warped wood and salvaged glass. just to name a few
I hope you enjoy
Step 1Tools and Materials
Tools and Materials
  • last photo ←
WOODWORKING TOOLS
-skill saw
-table saw
-jig/scroll saw
-compound radial arm mater saw
-orbital palm sander
-cordless screw driver
-drill bit (1/8 of an inch)
-counter sink bit
-philips drill bit
-drywall square
-tape measure
-assortment of clamps
METAL WORKING TOOLS
-MIG welder
-grinder
-port a band
-electric drill
-wire brush
-tape measure
-right angle clamp
WOOD WORKING MATERIALS
-4'x8' sheet of fourth inch ply wood
-1x1 pieces of wood roughly 10-20 feet
-3/4 screws
-1 screws
-wood glue
-silicon caulk
-wood filler
-KILZ latex primer
-generic red spray paint
-blue painters masking tape
METAL MATERIALS
-angle iron
-re-bar
-metal ring
-some sort of metal object to make into a hinge
-3 long 1/2 bolt ,nut and washer
-KILZ original spray paint
-rust-oleum flat black spray paint
SAFETY GEAR
-eye/face shield
-ear protection
-leather work gloves
-welding leathers
-welding mask
-leather shoes
MISCELLANEOUS
-shovel
-small buckets with water tight lids
-insect spray
-wet dry shop vacuum
-large bin or tub that will hold water
-piece of glass for the top of the form to contain the ants
-portable awning
-weather stripping
-spring clamps
-zinc and aluminum (melted soda cans work great for the aluminum)
-fire bricks
-propane
-propane torch
-crucible
-paint brush
-pressure washer
34 comments
Mar 27, 2011. 10:48 AMchicopluma says:
the feeling you described is an epiphany, i also had them while in my sleep.
the only problem is that your table looks like made by spiders, no by ants haha
Jun 14, 2009. 7:42 PMArbitror says:
Way to copy my 3D picture effect!
I don't mind though! Good job!
Jul 3, 2010. 1:51 AMTheParadox says:
This effect has been featured on Lifehacker and many large sites. Its no secret. haha
Jun 15, 2009. 9:40 PMArbitror says:
Oct 21, 2010. 11:18 PMTheParadox says:
I honestly don't think you did that right. It does not appear 3D to me and the "shaking" effect is not there. Yours is more a panning. Compare both images and you will see what I mean.
Nov 25, 2009. 8:07 PMpacwoods says:
Fire ants?? yow! they are dangerous and painful!
Jul 29, 2009. 9:43 PMpaqrat says:
Back in the 70's a friend of a friend told me about something he had tried. He was making castings of ant nests using molten lead. Advantage to lead , it melted at a low temp and was heavy so it filled the nests well. I think with some of other metals you might have a surface tension problem getting it into the holes of the nest. I think that might also be a problem with resins.
Apr 15, 2009. 6:45 AMjeff-o says:
Ouch! I've never seen a picture of a pressure washer "burn" though I've heard of it. Apparently a minute amount of oil from the compressor can be forced under the skin, which is what causes the infection.
May 20, 2009. 5:26 AMcountable says:
Pressure wash burn is nasty stuff. Ever wonder why they use water pressure cutters instead of conventional drill techniques? Because the water can be so finely focused it can cut insane designs out of really brittle materials (it was on american chopper, they used their new water jet cutter to cut a statue out of a carrot and tried the same thing with a drill. Safe to say the carrot got mangled with the drill).
Apr 29, 2009. 5:50 AMchuckr44 says:
In 1983 I was puring hot wax down anthills for a science project. So Mr. Tshinkle did not have the original idea. But using molten metal is better because the wax was a bit brittle and the delicate off-tunnels broke off easily. Though the main nest remained in one piece.
May 4, 2009. 4:31 AMchuckr44 says:
No pics. That was a long time ago.
Apr 30, 2009. 5:14 PMMaster Roda says:
This table doesn't look usable (although cool looking). Can you actually put a chair under it as normal?
Apr 25, 2009. 11:02 PMbenitaasmith says:
WOW!!! WHAT AN AWESOME PROJECT. MAYBE THOSE ANTS COULD BE GOOD FOR SOMETHING OTHER THAN BITING AND BUILDING MANY MINI-MOUNTIANS IN THE YARD. DINNER ON AN ANT HILL---I'LL HAVE MINE CHOCOLATE COVERED THANK YOU
Apr 17, 2009. 1:32 PMRadBear says:
Maybe if you smeared honey or some other food on the bootom of the mold before you filled it with sand the ants would be drawn to the bottom.
Apr 17, 2009. 12:56 PMrachel says:
Wow, that's a fantastic idea and execution. it is always amazing to see the things people come up with to make.
Apr 17, 2009. 12:18 AMDainiusGB says:
wow cool idea, massive project.
Apr 15, 2009. 10:57 PMalex-sharetskiy says:
what's the deal with the first picture?
Apr 15, 2009. 8:31 PMflio191 says:
poor ants, great job! what a long term investment for something you will never see the result of until the very end.
Apr 15, 2009. 10:29 PMflio191 says:
haha, hey, guess what, you're my hundreth comment! congrats. anyway, yeah, i can relate because i do film photography, though your wait was much longer.
Apr 15, 2009. 3:57 AMLftndbt says:
Nice effect. I was hoping you had constructed a table housing a functioning colony though. That would be AWESOME!!
Apr 15, 2009. 2:21 AMsolo.card says:
Shame about the wrecking of all the ants nests...
Apr 14, 2009. 9:02 PMalex-sharetskiy says:
that's very cool! at first i thought that that was white yarn
Apr 14, 2009. 6:28 PMrobbtoberfest says:
Melting metal is awesome!!!!!!!!!!!!!!!!!!!!
Apr 14, 2009. 5:39 PMguitarman63mm says:
That .gif is really messing with my eyes lol.
Apr 14, 2009. 2:07 PMirromfh says:
Any particular reason (corrosive protection, strength etc) for the Aluminum? Any other materials come to mind that might not be as dangerous as molten metal? great ible very thorough.
Apr 14, 2009. 2:17 PMblablabla123 says:
nice thinking, great instructable! 11!1!1!!!!oneoneoneone1!! Cool pics- lol it did appear 3d.... :O
Apr 14, 2009. 1:35 PMgmjhowe says:
That is pretty awesome.
Apr 14, 2009. 1:05 PMfungus amungus says:
Freaking great!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:somebullcrap
