Ac3 Assassin Tomahawk Hatchet
759
Published
Introduction: Ac3 Assassin Tomahawk Hatchet
I posted a pic of this, but this is the step-by-step. Il make it veeery easy to follow so anyone can make it. This is based on conner's assassin tomahawk in assassin's creed 3
Step 1: The Axe Head
The bladed section of the weapon
You will need:
Rods:
1 flexible purple
6 Green
2 blue
2 white
Connectors
3 green
2 red
1 white
2 yellow
Step 2: The Handle
the core structure of the handle
You will need:
Rods
1 green
1 white
2 blue
1 red
1 flexible purple
connectors
1 blue/white
1 yellow
1 red
Step 3: Reinforcements 1: Head
Makes it more durable
You will need:
rods
2 white
2 green
1 socket
connectors
4 green/purple
Step 4: Handle Reinforcements
makes the handle stronger and easier to hold
You will need:
Rods
4 blue
4 green
1 white
4 flexible purple
Connectors
2 green
2 blue/white
2 yellow
2 red
1 grey/connector
Handle section
Step 5: Assembly
putting it together
You will need:
Reinforced head
Reinforced handle
bend the handle reinforcements back until the green connectors fit next to the yellow connector and all the blue rods are in line as in picture 1
clip the blue rods into the purple/green ports on the head as in picture 2
There you go, the finished weapon
Step 6: Using
grip the handle by the 3 purple rods with your ring and centre finger, then wrap the other 2 fingers around the red rod. This is the strong hold. To spin the weapon, release the red rod and spin around the two fingers
Use the black clips to attach the weapon to a holster or weapon belt
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    10 Comments
    you guys should build my assassins creed cane sword
    it was only based on the original "Assassin tomohawk", its actually more towards my own design for an assassin from the 1930s in dustbowl america
    the handle is rather sturdy, the head is pretty flimsy tho.. if one were to (and im not saying to try this) switch the head for a segment from a razor disk, them you're talking
