3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
add beat lamps to your portable speakers or pc speaker...
have you ever wanted your some what small portable audio speakers or pc speakers to look like the same as if you were at the club??? well in this instructable il show you how to get your speaks wid the the site and sound of the club...
Step 1What you will need...
you need...
2X 12v LEDs (or more if you like(any color))(if you like you music really loud you will need to put in some resistors or higher voltage led's)
2X led holders (only needed if you are mounting them to the speaker housing(requires drilling if you go this way))
1X spool of wire (any color(its not complicated so you only need one))
I recommend heat shrinking the connections
oh ya and a set of speakers
tools you will need...
soldering gun and solder
drill and bit (if your mounting them in the speaker housing)
screw driver (to take your speakers apart)
20 comments
Jun 11, 2009. 6:10 AMnerdyidiot1 says:
for say a portable radio would it be possible to attach different collour LEDs to the speakers and to the BASE so you get two seperate led rythms...
Jun 2, 2009. 1:24 PMhg341 says:
i have a 60 watt base i think ill do this when i get the money
Jun 2, 2009. 7:32 PMhg341 says:
yea know I was not planing on taping any wires at all you know the wires will make em fildes
Jun 3, 2009. 3:08 PMhg341 says:
electromagnetice's
it works like a phone tap
http://www.instructables.com/id/cheap-working-phone-tap/
Jun 4, 2009. 6:09 AMhg341 says:
well im going in to electrical engineering so i should be good thanks though
May 9, 2009. 2:47 PMmarselsipod says:
it will blow the LEDS if you dont have resistors
May 13, 2009. 3:33 PMmarselsipod says:
oh.. I have some small pc spakers with no tweeter so i took it apart and it turns out it's 8V... I only have some high power 3v so yeah.
Mar 27, 2009. 6:59 PMTanyabear says:
i dont know much about sterio but i do know that this circuit is potentially destructive ...do not use on expensive equipment as the resistance this creates is similar to a short curcuit and screws with the ohms, you will damage your sterio.......
Mar 22, 2009. 12:45 PMwo2man says:
Yea i dont work....
Mar 19, 2009. 2:47 AMisacco says:
The instructions are clear and the final result (video clip) is nice, but some pictures would be welcome by the "Instructable" community
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:npa4863
I'm good with cars and motor and really good with computers and hacking... i like to think of my self as a high power mafia thug, i can get my hands on anything...
