3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
aerial shell for pyrotechnic display
This is for those of us who cant wait for standerd shells to dry, its easy and fun. its made from newspaper, white glue, superglue, a ball (or object that will fit your needs), and a hair dryer.(It also recycles old news paper)
Step 1Prep
Prep
white glue, white glue solution (75/25 water/glue), super glue, object wraped in plastic wrap, news paper, razor, scissors, Q-tip, hot air hair dryer.
19 comments
Jan 10, 2012. 1:22 PMAron313 says:
howd you make the lift charge.
Jul 12, 2010. 5:25 AMejay_99 says:
is the description incomplete?
Jun 26, 2010. 3:21 PMjaymanx says:
just burn the fuzz off of a tennis ball then cut it in half
Mar 8, 2009. 7:34 AMlemonie says:
Hi
The image you've shown looks far too thick - you want something thinner and 'crispier' than this. You're also lacking the details to turn the two halves into a shell - is this as far as you've got at the moment?
L
Jul 22, 2009. 9:31 AMpyrofirelighter says:
once you've got the two halfves and filled them, just put them together and glue and kraft paper it, i guess
Jul 22, 2009. 10:41 AMlemonie says:
See <strong>tudgeanator</strong>:<br/><a href="http://www.instructables.com/id/How-to-make-Aerial-Shell-Hemispheres/">http://www.instructables.com/id/How-to-make-Aerial-Shell-Hemispheres/</a><br/><br/>L<br/>
May 19, 2009. 10:38 AMtudgeanator says:
How thick should I make my shell? Because you have to paste the shell after you have made it, sooo what thickness should I make the shell on the ball, and then what thickness should I paste it? If I wanted to make a '3 inch' shell what would its actual final diameter be, because the inside diameter of a 3 inch mortar is exactly 3 inches! Thanks in advance
May 19, 2009. 10:55 AMlemonie says:
You want it tough and 'crispy', probably 1/8" - but look around for real values. Inner diameter should probably be 23/4" - unless you can make it very perfectly spherical you'll need the outer diameter to be a bit less than the 3" tube.
L
May 19, 2009. 11:35 PMtudgeanator says:
Thanks, so i'll form it round a 2 3/4 ball, at about 1/8 of an inch thick, cheers
May 19, 2009. 11:40 PMlemonie says:
Well, best wishes, the material does make a difference too - should be fairly stiff when it's done. L
Jun 13, 2009. 2:33 PMtudgeanator says:
Thanks alot for your help, i have now made my first few shells using a different method which seems to work very well. I made an 'ible on how to do it so check it out!
Mar 8, 2009. 11:43 AMlemonie says:
I'll look forward to the rest of it! L
Mar 13, 2009. 4:50 PMexplosivemaker says:
....might want to get a license/etc. before making your own fireworks, especially aerial ones....
Mar 15, 2009. 10:39 AMexplosivemaker says:
.....its actually BATF (alcohol, tobacco, firearms)......around here pretty much everything is illegal except sparklers.....if it explodes, leaves the ground, or moves at all, you technically aren't supposed to have it.....I have made smoke bombs, which aren't illegal here....but until if and when I get a license, I am going to stick to non-exploding (homemade) stuff.... ....although around the 4th of july, you can hear mortars going off pretty late at night.....the cops don't seem to care that much.....
Mar 16, 2009. 9:56 AMexplosivemaker says:
....feel free to put the letters in what ever order you want but the correct order is BATF or ATF.....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Twotails
