Remove these ads by
Signing UpStep 1Materials needed
1- 2" pvc/abs end cap
1- 2" pvc/abs coupler
1- 2" pvc/abs threaded end cap and threaded sleeve (find an Oring to put in female part)
1- 12" section of 1" corrugated tubing with threaded ends(1 Oring to fit over threaded part)
1- brass sprinkler head ( 90, 180 or 360 degree)MUST thread on to the corrugated tubing threads
Short section of rubber tubing that slides over the threads of the corrugated tubing
1- Steel tire valve
1- section 6"-6 1/2" long of threaded 2" galvanized pipe
2- 2" galvanized end caps
1- 3/8" ball valve (must open easily, look in air tool supply )
1- 4" spring (1/16" wire diameter, must be able to open valve)
2- 3/8" male to 1/4" female pipe adapters
2- short 1/4" nipples (male)
1- 1 1/2" long 1/4" nipple (male)
1- 1/4" T (all female)
1- 1/4" plug
1- section of 1" x1/8" steel strap
1- 2 1/2" long cotter pin
Some 1" x 1/2" wood
Some 3" wood screws
1- tent steak
1- Key ring
Some short self taping screws
Short piece of thin wire to make hook
Several yards of upholstery thread for trip wire
8" of surgical tubing
1- 16 floz water bottle
1 Small hose clamp
1- small plastic/metal nipple
comments
Add Comment
tobster9103 (author)
says:
Add Comment
