3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
air pressure tank for lego out of a lighter
here's an instructable how to make a small air pressure tank for lego out of an empty lighter
I decided to make it because I couldn't find an original tank from lego
I know it's rather small but if you want to you can link more together to get more volume
I made this tank without using any glue because I wanted to be able to reuse every part.
also there is no danger of explosions if u use an empty lighter please make sure he is realy empty you can lay him outside for a day with something around the valve to make sure he is empty
I'm also sorry if my language isn't so good
I'm from belgium so sorry if i write some mistakes
Step 1Getting the materials
getting the materials
what you'll need is:
an empty lighter, I took an ajustable lighter so the system takes out easy
a piece of lego pneumatic plastic tube
and a small piece of rubber tube from lego
you'll also need a drill to cut a hole in the system it will be explained later
underneath you'll find some picture's of all you need
13 comments
Oct 4, 2011. 5:00 PMplywood24 says:
Nice job, but why do you refer to the lighter as "He" ?
Nov 16, 2010. 3:55 PMtzq33tdq says:
can it be under lots of pressure??? THIS IS AWESOME!!!!!
Jun 17, 2010. 8:22 AMnerd12 says:
how does a lego set involve a gas tank? to make it move pneumatically or to make it explode? pls reply
Sep 13, 2009. 7:13 AMabsolute zero says:
but can you re pressurize the lighter when it completely runs out?
Sep 29, 2009. 3:27 PMabsolute zero says:
oh, and do you think a bicycle pump would work?
Sep 29, 2009. 3:25 PMabsolute zero says:
ty, i meant could you pressurize it with air when the psi was to low to do anything, but i guess i was unclear.
Sep 27, 2009. 1:22 PMReCreate says:
At how much PSI? I don't want an exploding lighter...
Sep 29, 2009. 12:06 PMReCreate says:
ok...
Feb 26, 2009. 4:00 AMPazzerz says:
Another good tank is a spent CO2 cartridge with the top threaded and a brass needle valve screwed into it. Nice Instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:a_k_a__wolfboy
