Air-soft Smith &wesson KWC Field Strip
667
Posted
Introduction: Air-soft Smith &wesson KWC Field Strip
To begin with, this is my first indestructible so comments are welcomed.The KWC is a great beginners gun. It is spring powered ,witch means you have to cock it for each shot.Let's start off with the hand-guard.
Step 1: Hand Guard
First ,before you need a small screw driver to get a pin out that is located near the bottom of the handle.Then, slide the hand-guard off of the handle.
Step 2: Slide Removal
To remove the slide, turn your gun to the side opposite of the safety. You will see a little nob or button then with your screwdriver push out the safety.The easy part is removing the slide to reveal the springs and the barrel (To make mine work better I sprayed rem-oil on the springs).
Step 3: Closing Notes
This gun is similar to the Crosman stinger p311,a cheap springer good for snipers as a secondary.It's what I use when I snipe.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
