Step 2Prep plastics
(ignore this paragraph if you don't have a cover for your container) cut the center out of the folgers cover keeping the sealing ring intact. This will be used to seal the plastic bag, if your bucket doesn't have this option don't worry, just use duct tape as described later on.
Cut the thredding sides off of the milk caps to make flat hard plastic washers. Melt a hole through the center with a wire heated in the candle.
Cut a hole in the center of the bottom of the folgers container. This one's 2" dia. Doesn't really matter how big unless you want to get into the formulas of how much air your chute pushes. Also melt 4 holes around the edge as pictured. Must be just big enough for your string to fit though.
Add Comment
