Introduction: Airsoft Back Stop
update i have made a much much smaller/better backstop instructable coming soon update
this instructable is an example for your own back stop your back stop will be unique so be careful when first testing expect ricochet always use eye protection.
build this:
in a safe area away from valuables breakables and stuff you dont want holes in
where people arent walking about on a daily basis ie. kitchen living room tv room ect.
Your bedroom could be used if you have enough room and dont have breakables
I have had no collateral damage from using my back stop so far this dosnt mean you wont .Instructables header
- You
FavoritesImage LibraryUpload ImagesSettingsLogout
- Explore
AllArtCraftFoodGamesHomeLifeOffbeatRideTech
- Forums
View AllNew Topic
- Groups
Lion Brand Yarn Challenge Win a Laser Cutter Contest Homemade Holidays Contest
- Submit
New ForumNew GroupUpload ImagesBug Report
This Instructable
- Add New Step
- Reorder Steps
- Change License
- Delete Instructable
- Version History
edit
preview
collaborate
publish
saving
saving...
add new stepinsert following stepdelete stepsave & finish later
intro
5
Title:
Description:
Link Name: Link URL: add link
example: My link example: https://www.instructables.com/
Video: by px add video
example: http://www.youtube.com/watch?v=VCls6-WpqV4
Supported video formats include Google, Yahoo! and YouTube. [more info]
for bold text type bold text
for italic text type italic text
for monospaced text type {{{
monospaced text
for a link type a link
I just got a airsoft gun but i have no where to shoot it safely so i built my own back top to stop and catch the airsoft bb's i have only used this with a cheep spring powered pistole, 275fps this should work on bb guns up to 400fps using .12g bbs however i have not used a higher powered gun on my back stop. your results may vary this instructable is an example for your own back stop your back stop will be unique so be careful when first testing expect ricochet always use eye protection. build this: in a safe area away from valuables breakables and stuff you dont want holes in where people arent walking about on a daily basis ie. kitchen living room tv room ect. Your bedroom could be used if you have enough room and dont have breakables I have had no collateral damage from using my back stop so far this dosnt mean you wont . in video i reload 3 times and several times i shoot off target to show that its stoping the rounds now that all the boring safety crap has been said we can begin ;D
loading...
560x420 : FUZPPT0F52SMQ8M (4)
target
[delete][edit]
i make shooting things
back stop
[delete][edit]
thing holding up target
[delete][edit]
this is my original backstop (not one in instructable)
[delete][edit]
[cancel]
[save]
feedback here...
Adding Image Notes: Click and Drag your mouse on the image above to create notes.
Attached Images and Files:
The first image is the "main" image. Drag to reorder.
remove
Add Images and Files from your Library
remove
remove
remove
remove
remove
remove
Add from:your library(instructable library)
view by tag:
view by file type:
add
Your Library is Empty
Import photos from Flickr, Its Easy!
Email address/User name :
The email address should be associate with your flickr.com email address Or the user name that is used for flickr.com.
Sorry, there is no tags in your account at flickr.com
Sorry, there is no photoset in your account at flickr.com
Recent uploads
add
Upload new images / files using the Browse... button below.
Upload Images / Files
Check out our beta Flickr upload tool available in your library!
tag files as upload
(separate multiple tags with spaces)
loading files Please be patient, this may take a while depending on file size and connection speed.
You must keep this window open for the file to continue uploading!
hey, this is my error!
cancel save & preview save & edit next step »
Step 1: Get the Stuff You Need, and Understand How It Works
tape, duct and scotch several grocery bags (these will be the stoping force of the backstop dont belive read on)a old bed sheet (secondary backstop, if you miss or if it goes through)paper folderpaper target
if you have carpet you could just have a large piece of card board instead of the blanket
this works on a simple proses of trapping and absorbing the low density plastic bb's if you dont this this will stop bbs take a bag fill it with 3-5 other bags go out side set down bag back up and shoot it all the bbs should be stopped and will be ether inside bag or will lightly bounce off and will be on ground.
the bed sheet is gona catch the ones that bounce off or if your a horrible shot will stop them too (they might bounce around after they hit bed sheet but they will have slowed down a lot
Step 2: Create the Blanket Back Stop
this step is the hardest because i can not help you. your back stop will be differant from mine cause you didnt not build it in my storage room (possible great place to build one if you have one long and narrow mines 30 feet long theirs about 10 feet behind the back stop you cant see in most photos )
this is hard to exsplane so look at the pictures if you get confused
1now you want to have the blanket run from the top of celling down but not to the ground
2 you what to have the blank cover the sides.
3have the end of the blanket bank up
4it the part that slops up has to be kinda forward to so that it catches the ones that fall
Step 3: Build Bag of Bags
this is simple get a couple bags stuff them in one bag see pic on how to tie/twist shut
Step 4: Set Up Folder and Test
tape folder so it hangs down about 1.5 feet from front of backstop, (look at pics)
then tape bag so it hangs on the back of folder (look at pics)
test. dont put up target yet, step back and fire just 1 round and see if it bounces, ricochetes, absorbs, or goes strait through (if it goes strait through fill bag with more bags and try again if it still goes thought then ur gun is to powerful) if it bonces that ok as long as it lands on the blanket and rolls where all the other bbs are.
remember this instructable is an example on how to build one of your own. yours will look different but should stop and collect bbs
Step 5: How to Put Up Target/maintenance
the target should hang down so the bullseye is just slightly below folder, or in center of bag
at the end of day you should take the bag off , open it up shake out each bag inside, this way you can keep the bbs that penetrate the bag. then just put bags bag in bag tie it up again and tape it up. good as new
