airsoft claymore(not technically a claymore)
 by instructaBAD
yes.  this in not technically a claymore, but it serves pretty much the same purpose as one and it is way simpler to make (it only took me about 10 minutes to make and it was definetly worth it).  it is great for ambush at airsoft wars and requires very few materials.  this is my first instructable ever so spare me if im doing a bad job and please try this project out and leave comments!!!!!!!!!!!!!
Step 1: Materials needed
electric airsoft gun ( your not doing anything to the gun that cant be undone so don't worry, use your 450 FPS gun)
backup airsoft gun battery (doesn't have to be the specific battery type that comes with gun it can be any airsoft gun battery)
electrical switch
lots of wire
electrical tape
wire strippers (or you could a pocket knife blade like me)
iloughney says: Apr 4, 2012. 6:28 AM
In theory I think instead of a wireless, you could build an electric tripwire (which there are probably hundreds of instructables on). the only thing is it would keep firing till the mag was empty/battery was dead, so it might dry fire a lot, which isn't good for the gun...
the mechanical engineer says: Feb 9, 2012. 2:08 PM
although this is a pretty common idea, the documentation is very good for your first 'ible. however, there are quite a few ways to improve it, all depending on your level of skill in electronics. If your more skilled, you could look at my instructable here on how to create a remote detonator. in order to make it a manual remote trigger, just wire this up with a simple relay switch and your done. it also wouldn't be hard to make a pressure plate detonator, using my idea here, or a tripwire detonator here(note that with the tripwire detonator, the gun would continue to fire until somebody dissables it, wich could be a rather bad thing.) also props go to scissorman on the tripwire instructable. also, with the links i provided to my 2 'ibles, you will need to use some common sense and problem solving to get them to apply directly to your "claymore," but judging by your work i'd guess thats probably in your skill range. congrats on your first ible!
kve23 says: Apr 16, 2011. 11:39 AM
what about a steel tripod with a wheel on it and a c-clamp put sideways to clamp your gun
spark2FLAME says: Mar 30, 2011. 3:00 PM
PVC is the solution to everything. Just cut it to the correct length, get the correct joints, get end caps, give it some paint, and mount it to your airsoft gun using whatever and there you go, a tripod! Hey what airsoft gun do you have?
instructaBAD (author) in reply to spark2FLAMEMar 30, 2011. 3:15 PM
its a pulsar 76 yeah i know its crapy but i took of a bunch of peices to make it look cooler thanks for the idea
instructaBAD (author) says: Mar 30, 2011. 1:21 PM
I figured out how to change my username so now it is instructaBAD. ( with a R)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
