this is cool. im still working on issues with the propellant, so it dont go to far. but o well. im also working on the rocket to. but maybe yall can comment on some stuff that will work
Step 1: Build the tube
take 3 or 4 pringles cans( 4 works the best) and poke holes in the bottom about the size of a quarter. then duct tape them end to end. next take one final can and tape it to the bottom. this will be the combustion chamber. now wrap it in like fidy layers of duct tape, wire and watever else you can find that will add strength to the tube.
Note: be sure to wrap it in A LOT OF DUCT TAPE!!!! gorrila tape works better though, and its also a good idea to take the bottom off of vegtable cans and tape to it to add more strength. a good weak point to reinforce is the bottom of the last can. it blows off really easy. i can not emphasise how important this is. if you are thinking, "this is bull, ill do what i want", no. im sorry, but ive tried it and had two launchers explode on me. it is not fun.
1-40 of 55Next »
Tbirdfisher says: Feb 16, 2012. 9:44 PM
If you take paper, make a firecracker sized roll, tape one end, slide a firecracker down it, put the fuse through the hole, fill it with ammo, and stick that down a piece of PVC pipe, instant RPG.
eman414 says: Aug 12, 2010. 10:22 AM
could you post more pictures?
nerd12 says: Jun 18, 2010. 6:38 AM
you should not hole it on your shoulder or if it fails it will take your head off. keep it on the ground like a howitzer
120012 says: Feb 19, 2009. 12:26 PM
Dude all i used was a little bit of propane and it launched it like 100 ft!!!
the mechanical engineer (author) in reply to 120012Feb 19, 2009. 2:07 PM
SERIOUSLY!? how did you get the propane? i want some, cuz i ben using a combo of rubbing alchohol and lighter fluid
120012 in reply to the mechanical engineerMay 26, 2010. 6:20 PM
 i went to the store and bought it
120012 in reply to the mechanical engineerApr 10, 2009. 6:41 AM
I went to the hardware store and got a mini bottle
120012 in reply to the mechanical engineerApr 9, 2009. 2:30 PM
I went to the hardware store and i bought one of the mini bottles for the bbq!!!
geoffypi in reply to the mechanical engineerMar 1, 2009. 3:26 PM
open the valve on your blowtorch but dont light it the gas that comes out is propain
the mechanical engineer (author) in reply to geoffypiMar 2, 2009. 5:48 AM
cool. thanks man. now i just need a blowtorch
whitelion331 says: Nov 26, 2009. 10:30 PM
Hey if you want a really cheap fuel source, hairspray might just work. I haven't gotten the chance to test it though...
But my friend, he tried it with a potato launcher and it left my other friend with bruises...
the mechanical engineer (author) in reply to whitelion331Dec 2, 2009. 6:02 AM
yes it does i have recently tried hairspray as a fuel source and broke my fence again with it. (curse city living) however i tried it in the country and it didn't get very far. i am now, however, working on a new rocket desighn to give it better range.
tarku4 says: Nov 1, 2009. 12:31 PM
i have a potato gun and bean bags work great for it so you might want to try a bean bag
andi456 says: Aug 25, 2009. 3:26 PM
Isnt this just a potatoe cannon? Just use a potatoe cannon and make some sort of capsule to hold the BBs until they impact.
the mechanical engineer (author) in reply to andi456Aug 26, 2009. 6:44 AM
actually, its just a modified tennis ball mortar, but it works.
sharlston says: May 7, 2009. 11:27 PM
use hairspray or wd40 its well good it gets me 150feet
daelans in reply to sharlstonMay 21, 2009. 6:16 PM
if you figured it out, think you can make me a better ible of it and post it somewhere (its "legal" as long as you say its his rocket launcher) cause all i got was put pringles togethor and poke ONE hole in it. so, im totally lost.
sharlston in reply to daelansMay 22, 2009. 3:05 AM
i might soon
daelans in reply to sharlstonMay 28, 2009. 1:10 PM
ok ty. this is still a god ible, and idea but i cant make heads nor tales.
tehgreatiam says: May 20, 2009. 5:47 PM
wait, i see nothing that relates to airsoft.
geodez says: Apr 28, 2009. 8:38 AM
you needs to be a-firing tennis balls 3 or 4 at a time yeah?
ChefZombie says: Apr 9, 2009. 12:43 PM
This seems dangerous
geoffypi says: Feb 9, 2009. 4:53 PM
it would be safer if u used pvc pipe and commpressed air. but it would much more expensive ($50-$70)if u don't have the cash u can use whatever u used and a scru on end cap.(check it out on you tube)
qballcat in reply to geoffypiFeb 21, 2009. 10:35 AM
i made one for 17 bucks that shoots photo cannisters OVER 200 feet, beat that (thats at 40 psi it can go to 100)
geoffypi in reply to qballcatMar 1, 2009. 3:34 PM
I can beat that I know mines expensive but it can shoot 300gram (little over halve a pound) projectiles over 200ft i usaly get it to 60 psi but it can go up to 200 and blow holes through 1 inch pieces of wood but if yours is still better i can under stand.
qballcat in reply to geoffypiMar 1, 2009. 4:08 PM
1inch? wow i can only do plywood i dont know how much half a pound is (to exact) but thats impressive
geoffypi in reply to qballcatMar 5, 2009. 7:38 PM
thanks,yours sounds cool to i'd like to see it
qballcat in reply to geoffypiMar 5, 2009. 8:10 PM
here you go
geoffypi in reply to qballcatApr 1, 2009. 5:28 PM
Here's mine!
qballcat in reply to geoffypiApr 1, 2009. 7:45 PM
nice, i like the corrugated-ness
geoffypi in reply to qballcatApr 2, 2009. 12:44 PM
thanks
the mechanical engineer (author) in reply to qballcatFeb 23, 2009. 5:48 AM
yup. Tis one blew a hole in my fence with a water bottle
qballcat in reply to the mechanical engineerFeb 23, 2009. 7:54 AM
lol hole in plywood (2 sheets) with a dowel ive re tryed at 60 psi it can go up to 450 feet (150 yards) and i have plans for a better one..............................................
the mechanical engineer (author) in reply to qballcatFeb 24, 2009. 5:53 AM
post an ible......................... NOW!!!!!!!!!!!!!!!!! I WANT IT!!!!!!!!
qballcat in reply to the mechanical engineerFeb 24, 2009. 7:38 AM
know what, i will
use606 in reply to geoffypiFeb 18, 2009. 2:31 PM
BULL i built a air cannon in a hour and with $11-$20 of pvc stuff and a stem valve. for ammunition just take a plastic bag and put some bbs in it finally tighten it up and tape the tail it will explode on impact.
the mechanical engineer (author) in reply to geoffypiFeb 10, 2009. 5:50 AM
actually this is pretty safe, and if you want you can put pvc around it to make it more sturdy.
geoffypi in reply to the mechanical engineerFeb 10, 2009. 4:37 PM
about how fast do the projectiles go?
the mechanical engineer (author) in reply to geoffypiFeb 11, 2009. 5:58 AM
i don't own a radar gun, so i dont know, but i got one of those big prifacy fences and it shot a water bottle half full and put a hole in it from clear across my yard, so its pretty powerfull
potatoecannonfreak1995 says: Mar 25, 2009. 1:12 PM
I have a air cannon I built for 35$ and it can shoot mini tennis balls 250 feet at 10 psi ive taken it up to 110 psi and i can shoot it over 800 feet and its pvc
1-40 of 55Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
