3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
airsoft tips and tricks
This will be an ible that I will update when I come accross more interesting stuff, and as I learn more about airsoft. Its for all the little stuff that doesn't warrent a whole instructable. Its also an attempt (perhaps a vain one) to add something new to the growing number of "airsoft for idiots" guides that all say essentially the same thing.
First tip:
Don't look conspicuous: it draws fire.
Don't draw fire. It irritates the players around you.
Don’t irritate the players around you: It makes you looks conspicuous.
Step 1Profile: playing tight
Profile is how much of you there is for the enemy to shoot at. You want a small profile so that you are less likely to get hit.
Playing tight is staying as close to your cover as possible to minimize profile.
Try to:
Keep your elbows in.
Keep the muzzle of the gun behind the corner so you can snap back behind should the need arise.
Shoot lefty around the left of cover. Shoot righty around the right of cover.
Remember to keep your legs and butt in. Its easy to forget that these are not in cover.
Distinguish between cover and concealment:cover blocks incoming fire, concealment hides you but may not block bbs.
If you remember to do all this you will be less likely to be hit. In the pictures I highlighted what would be available to shoot at. The first one is bad form.
Quick tip: by placing the elbow of your trigger arm (that is, the one whose finger is on the trigger) on your rib cage and placing the stock on the outside of your shoulder, you geometrically guarantee that you have the smallest profile possible, so long as your muzzle is as close to the edge of cover as possible.
EDIT: Having had a few years more time to practice this, and having acquired a better camera, I will ideally be slowly rewriting this over the next few months.
81 comments
1-40 of 81next »
May 1, 2009. 2:47 PMwaverider894 says:
dont forget you want the shoulder pressure from the stock. in mil-sim paintball (might apply to airsoft) it reduces recoil and the gun will be more steady while looking down the iron sights or what every sight/scope is attached
Jul 27, 2009. 6:20 AMCapnTac says:
Airsoft guns have no recoil??? Really??? Then how do you explain Gas Blow Back guns???
Oct 28, 2010. 8:37 PMyobwoc says:
Right, GBB's have obvious recoil. Also, AEG's have "recoil" in a way. They don't hurt your shoulder and blow backwards real hard like a shotgun, but they vibrate. It gets annoying.
May 8, 2012. 1:10 PMilpug says:
A good AEG will not vibrate, and if it does, there is probably something wrong with it.
Jun 4, 2009. 12:20 PMdaelans says:
also, stocks just make it a little easier for looking through scopes and sights, just press against your shoulder to stay steady
Apr 24, 2011. 12:31 PMPaintballer98 says:
In the second pic that is such a good idea taping the pistol (preferably gluing though) to the gun is a way better idea than putting on a foregrip
May 8, 2012. 1:08 PMilpug says:
That was a joke.
Feb 3, 2012. 6:42 AMairsoftgunguru says:
I agree with wunmanbands comment! It is really important to read and follow istructions! Airsoft Guns are not just a simple toy! Remember that you're not holding a water gun like your little brothers toy... You will need a lot of safety precautions...
Pat
Aug 3, 2011. 11:37 PMilpug says:
this is a pretty good Airsoft Ible'. has actually useful info. good job. keep the entries coming.
Jun 23, 2011. 3:14 AMaRejectedKitten says:
ok two things 1. the weights help you aimthey balance out pretty much the whole freaking gun and 2. who gives a flying rat's buttox if ur carrying an extra 1 pound? It's barely even noticeable.
Apr 30, 2011. 1:17 PMunclex6 says:
U CAN DODGE BB!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I HAVE
SO HAHAHAHAHAHAHA
U WERE WRONG
Mar 15, 2011. 3:05 PMabryant says:
y dont u just get fiberoptics
Mar 3, 2011. 1:19 PMzreisner says:
I just made a similar post on my blog www.airsoftinfo.wordpress.com about how to avoid getting shot.
Jun 28, 2010. 10:32 AMzephyer55 says:
One time I was running to the right and my friend shot an automatic in front of me and I dove over the stream of fire and rolled under the next. I tried again but got shot, several times.
Jan 22, 2011. 11:09 AMthing 2 says:
Nice!
Dec 24, 2010. 2:30 PMfranzwa says:
i dodged a rpg round comeing to my face in a airsoft war and it was no fun i can tell u that ( and dont ask yes we are sick we use rockets and explosives and some nasty chem stuff sometimes) oh and i go rambo on the battle field i one hand m4a1 the other hand g36c both with drum mags and extra batteries
Dec 22, 2010. 1:59 PMhobbitboy says:
like avoiding meudusa never would have thought of this for airsoft smart
Jun 12, 2010. 10:37 PMwunmanband says:
once i was playing a game, and the other dude on my team got shot in the mouth by a sniper. he walked up to me and spit it by my boots. i guess he didn't read this instructable.
Dec 22, 2010. 1:57 PMhobbitboy says:
if gotin shot in the mouth it hurts
Apr 27, 2010. 7:15 AMairsoftbeast40 says:
I ONCE DODGED A SNIPER SHOT THAT WAS COMING FOR MY FACE =)
Oct 28, 2010. 8:33 PMyobwoc says:
Good idea. I think you just might be made famous for your new combat trick.
Oct 30, 2010. 8:15 PMairsoftbeast40 says:
f%ck yes i will
Sep 28, 2010. 1:57 PMfunkybassman105 says:
phosphorescent
Sep 30, 2010. 1:50 PMpredatory meatball says:
good idea with the gear turning, but instead of sacrificing FPS and range to a weaker spring (although it will considerably raise ROF) you can get the Systema Silent Piston Head ($30 well spent), wich considerably reduces the slapping piston sound by molding better into the cylinder head
Aug 9, 2008. 10:42 AMCapnTac says:
I wouldn't have taken it out of the sniper. If it is high powered, it might now be hard to aim and to keep still.
Mar 16, 2009. 9:44 PMcdawg14 says:
A sniper rifle isnt really made to be "whipped around". Your not really describing legit airsoft here. Yarn is not a "ghillie" And Glow in the dark sights will only prevent you from seeing your target. Also, removing weights from your gun can result in stress fractures in the plastic. weights keep the gun stable and reduce vibration in the body. without them the gun cant take the stress of firing.
Sep 30, 2010. 1:37 PMpredatory meatball says:
hmm... it is you thats not describing "legit" (how i hate that word) airsoft. As KGtheskater says, if you make the right pattern, yarn WILL in fact work GREAT. the phosphorescent sights work well if you do the tip of the front, and two dabs on either side of the peephole/ aperture in the back (assuming you use a rifle with sights simmilar to those on m4, m14, and posibly mp5). Most chinese companies put weights to make the gun feel strong, While decent ones MIGHT (they dont always put them on) use them for weight distribution. IF you truly play "legit" airsoft, you wouldnt have to worry about cracked plastic, because you wouldnt own plastic
Apr 21, 2010. 1:15 PMKGtheskater says:
Yarn in the right patterns and the right type could actually work to make a ghillie, i wrote an instructible on how to make one, no pictures yet but as long as you ruff it up and get the pattern right, then add natural twigs, its not professional but it would get the job done for an airsofter on a budget
Dec 10, 2009. 5:57 AMairsoft87 says:
AGREED. I once took weight out of my shotgun and forgot to put it back in before we started the war. The gun broke.
Jul 26, 2009. 12:44 PMA good name says:
Isn't it ironic how by trying to achieve being the best, he did just the opposite?
Jun 28, 2010. 10:35 AMzephyer55 says:
that's really smart i never thought of that.
Mar 29, 2009. 5:56 PMJ.D. Hound says:
Never put a cd in a microwave....NEVER!!!
Apr 27, 2010. 7:25 AMairsoftbeast40 says:
WHAT HAPPENS?!
1-40 of 81next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:Molybdenum(Mo's Airsoft Shenanigens)
