Step 2Painting. If you don't want to paint it, Skip this step
iImage Information
You're gonna want to take off the rail thingy. Just take your screwdriver and unscrew the two screws on each side and it should come off. Now. There's a little cap at the tip of the barrel at the end. It holds the front weight in there. Unscrew it and take off the strap mount. Now take off the barrel. It should slide off once you take the cap off. On top of the pumping part, there's a little screw. It holds the pumping part in place. Unscrew it and put the tiny screw somewhere you won't lose it. Take the pump thing off. Time to tape. Tape off the little balck rubber part of the stock. It will make it look fancy. If you want to paint the grip designs don't tape them. Otherwise, tape it up. Lay out some newspaper, paint, wait like an hour(I do, I'm impatient) it should be dry. If it's on a sunny day. And vwala. It's perty.
