3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
(almost) automatic paper recycler
This is an instructable where i will show you how to make an almost completely automatic paper recycling machine. It recycles old paper into new paper. It also uses recycled materials such as cardboard and drink bottles. It cannot be completely automatic because different types of paper take longer to process than others, so you just control a bunch of different switches. But it will do all the hard work for you. Please read through the entire instructable before you buy the parts. You might use different parts, and they can vary depending on what you have and need. The other cool thing about it is that you can put sparkles or glitter in the paper before it's done and have creative designs.
 I am a middle school student who made this out of discarded and found materials, and I constructed it all on my own in my garage -- so you can do it, too.
I will have more pictures of the paper and possibly a video soon...... I've just been really busy lately but i have a lot more because finals are coming up... :(
Step 1Get yer parts
Get yer parts
You obviously need parts to do anything or make anything. You need circuit boards for a computer, for a car, or anything else. It's the same with this. There are a lot of parts that you need, but luckily most of them are cheap or you can find by dumpster diving. Hopefully you can find all the parts. or you could improvise.
parts
1) Many 1 x 4  planks of wood. You really need a lot as the entire frame is made from these. You can usually find them in the trash, and if they are stuck together in a crate, just pull them apart. That's what I did. If you can't find any in the trash, just buy a lot. They don't have to be that strong. You should get at least two that are slightly more than 5 ft in length, (about 1.5 m) or around there. Along with that, get a flat length of wood. doesn't have to be that thick. but make sure it can carry a bit of weight.
2) Many wood screws. I don't think anyone will be throwing away any of these, so you can just buy a box of 100 for 3 to 5 bucks. You wont quite use 100, but just in case... I used 1 1/2 inch length. (3.81 cm)
3) A paper shredder. If you don't have one, you can buy a cheap one, find one in the trash (you might need to fix it) or rip up the paper yourself.
4) a wooden dowel. Get a pretty long one, about 4 feet. (1.5m) I used 1/2 inch thick. (1.27cm)
5) The parts for the mixer
5a) an old cd that can be cut up
5b) a gatorade bottle (The big kind, or a two-liter coke or sprite bottle)
5c) a powerful motor (a note: make sure you have a way to hook up the motor to the cd, to make the cd spin.)
5d) batteries to power the motor (or if it's plug-in, a power outlet) It's hard to make it water-proof
5f) If you have a blender (the lighter the better) that you can use, use that instead of all that other stuff. It's specifically made for that, so it would be better. You can get one at goodwill or salvation army or whatever for cheap. The basic action it will be doing is stirring up wet paper, and chopping it into mush.
Remember, it has to be able to tip over to empty everything out.
6) a few powerful gearboxes (make sure they turn slow) that will tip over (like pouring) parts of the recycler to empty the paper into the next area. I would get three. One a bit more powerful than the others, one a bit faster, and the other in between.
7) a turkey roaster. big enough and deep enough to hold all the pulp (shredded paper) By turkey roaster I mean the cheap tin ones that you can buy at the supermarket for a buck, not the expensive thick ones.
8) some sort of water tank. I used an old laundry detergent tank that had this little button on it that when you press it, the detergent (or water, whatever is in it, would come out.) Tide detergent bottle, to be exact.
9) cardboard and tape.
10) window screen, with small holes. Get about 8 ft by 1 ft or more (2.5 m by 30.5 cm)
11) three feet (91.44 cm)of 1" diameter (2.54cm) pipe, for the rollers to make the paper smooth.
12) A way to turn the pipe (one gearbox)
13) 2 dpdt switches to switch the motors one way or the other. (center-off)
(you might need more or less, depending on what you have.)
14) 1 on/off switch
(you might need more, depending on what you have.)
15) wire
16) various other parts that i'll explain later
tools
1) Drill with drill bits (make sure you have 1/2 in.) (1.27 cm)
2) a saw to cut the wood.
3) a permanent marker, to mark on things.
4) wire cutter and stripper
5) you also might need an x-acto knife
6) a ruler
7) a hot glue gun or other waterproof glue
8) a hacksaw to cut pipe
9) It might be useful to have a level.
22 comments
Apr 28, 2009. 8:03 AMSara Munoz says:
AWESOME1 I'M VOTING FOR YOU.
Apr 26, 2009. 9:00 PMEmijalis says:
I had no idea how creative and smart you are. I sure hope you WIN big!!
Apr 26, 2009. 4:55 PMmeviglucci says:
Awesome! You have my vote.
Apr 26, 2009. 7:29 AMmcviglucci says:
I'm looking forward to seeing some more creative designs and the video. Great work, Frankenboom! I'm voing now.
Apr 25, 2009. 7:15 PMblopeza says:
This is very promising. It has great potential.
Apr 25, 2009. 2:10 PMmviglucci says:
very impressive - i'd like to see more paper samples, like the sawdust with the old look...
Apr 25, 2009. 3:31 PMgluch says:
Great job. Very imaginative, very green. One more vote for Frankenboom.
Apr 25, 2009. 12:35 PMbilloates says:
How impressive! It is wonderful to have such an innovative environmental technologist around here. Things are looking up!
Apr 25, 2009. 11:20 AMjmassoth says:
Wow! I am so impressed! I'm glad you solved the problem of not having a circular saw or jigsaw.
Apr 25, 2009. 5:36 AMrayadverb says:
I think Frankenboom should win the Nobel Prize, at least.
Apr 24, 2009. 10:36 AMkaufsports says:
I saw the paper Frankenboom made with this recycler and it was VERY impressive. Would make beautiful stationary!
Apr 23, 2009. 5:17 PMlqstgr67 says:
iNtReStInG yOu MuSt Be ReAlY SmArT AnD A TeEn AgEr RiGhT????
Apr 23, 2009. 8:49 AMhoobert says:
I saw the recycled paper. It works great!
Apr 20, 2009. 3:27 PMnclub says:
Great idea! This must be the GREENEST instructable out there!
Apr 20, 2009. 2:55 PMEuphy says:
This is a great idea, but I'd like to see it working!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:frankenboom
