3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
altoids PSP recharger
This is my first instructable so don't judge too harshly. This project came to be when I thought "Hey, Sony is evil, they don't have any inexpensive alternatives to their battery packs" I find out now that other companies have made external battery packs (but what's the fun in buying one anyway!). So I set out on an epic journey to create an external battery pack for my PSP. Enjoy!
Step 1Procure components
procure components
first you'll need to get all of the parts and pieces.
1- altiods tin (flavor of your choice)
2- a +5 volt regulatora +5 volt regulator (what this whole project revolves around)
3- a dpdt switch or your choice (it should be pretty small)
4- a four AA battery holdera four AA battery holder
5- a LED for indicatora LED for indicator
6- a DC power connectora DC power connector (plugs into PSP)
7- mono phone plugmono phone plug
8- mono phone jackmono phone jack
9- 2 conducter speaker wire
10- various wires for connections
once you have that you're ready to go!
68 comments
1-40 of 68next »
Mar 13, 2011. 12:43 PMhuntudown4 says:
Thank you for the guide, but I found a much simplier solution to MY problem. I let my psp get completly out of juice, and I couldn't find the charger. So, I go online to find some re-charge solutions, and I foung this. I then dug through my old "spare parts" bin. And I found a 5v cell phone charger. So I took the Mono cord, and just soddered the two together. But I think you for your guide anyway.
Aug 26, 2010. 9:47 AMTaktar says:
Interesting, but unrelated little fact, that may already be well known: The fumes are more or less adhering to the oil in your fingerprints, so that cloudiness is palm/fingerprints, I think members of law enforcement use similar methods to get fingerprints off of 'strange' surfaces
May 24, 2010. 12:55 PMshanky887614 says:
would it be possible to buy this or one off you?
here is my email
oldwiseblack-1234567@yahoo.co.uk
Apr 22, 2010. 6:53 PMTitanTechRobotics says:
I know this is an old 'ible, but I thought that I would say that the reason that it is around "4.7 volts" is because with voltage regulators need about a 2 volt extra overhead.
AI
May 15, 2008. 5:47 PMbigt4616 says:
i followed all the directions and everything but i am geting no charge out of the jack
May 25, 2009. 4:37 PMfoxtrot4697 says:
if the orange light isn't lighting up on the PSP it probably is charging, but like he said, it is a bit under power.
Jun 27, 2009. 4:42 PM11richie21 says:
yea i agree because i heard green leds take less power to light than other colors like orange wjite and blue
*white
May 26, 2009. 10:50 AMbigt4616 says:
that really does not make any sense cause it probably has a circuit that lights a orange led when charging the battery. you need a certain voltage or it wont go. i learned this with a little thing i made up for this. it was a salvaged 4 battery pack. i just snipped a usb charger cord and soldered the wires on the pack. when the batteries started to die, they where putting out less voltage(what happends typically when aa's "die" ) they got below the 5V minimum and it stopped charging. i checked it with a multimeter too. btw, you really dont need to put any kind of resistor on the batteries because 6V isnt really going to hurt it that bad, if you need a longer charge, just go with c or d batteries(both 1.5 volts, just more power)
May 3, 2009. 7:06 AM466267 says:
Yo same here but i used usb instaed of jack
Sep 23, 2008. 4:03 PMpolo99a9 says:
me either...
Jan 31, 2009. 5:50 PMamakerguy says:
Dude its not charging in the picture (the red indicator light on the PSP is not on).
May 20, 2009. 7:45 PMCartuner55 says:
if you read, he said it doesnt always register because it is a little below power. but also, if you look at the altoids tin its led is not on either.
Jul 10, 2008. 1:45 PMCalcProgrammer1 says:
I would really highly recommend a diode to be included. Although it isn't essential, inserting the batteries backwards CAN AND WILL destroy the 5 volt regulator. This design marks the battery connections pretty well, but I used a battery pack connected with 9v terminals on my PDA/PSP/USB charger and my friend hooked the connector up backwards and fried the whole device. My new version with a diode eliminates this problem. Putting the diode between the batteries and the regulator means that power only flows one direction, preventing backwards flow that could destroy it.
May 3, 2009. 7:38 AM466267 says:
I just want to be safe when i finish mine up even tho this instructable doesnt work... the part w/o led and switch works... so what diode u reccomend .. plz post a link if u can ty
May 3, 2009. 7:33 AM466267 says:
what diode do u recommend?
May 3, 2009. 7:04 AM466267 says:
OKay. I made the charger diagram from the battery to the 5v reg to the usb ... that's the only parts that are recieving voltage from the batteries. idk what's wrong i have DPDT switch has 3 prongs and a led in a holder..... any ideas what im doing wrong plz reply
Jan 11, 2009. 9:37 AMLanceUppercut says:
is there a way i can make sure my wires for the dc connector from the phone jack have juice to them?
Jan 11, 2009. 9:03 AMLanceUppercut says:
could you get a closeup of the circuit i am having a hard time knowing what to do i did it the way the diagram shows i think but i don't get a charging light at all.
Sep 23, 2008. 4:05 PMpolo99a9 says:
no charge in the psp. is it because the regulator that you posted gives out 5V and only 1000mA? didn;t it need 2000mA? just asking.
Dec 15, 2008. 9:32 PMawang8 says:
Umm... Actually it needs 500mA (max) so the reason it didn't charge is because your battery's toast.
Dec 16, 2008. 5:21 AMpolo99a9 says:
I don't think that my battery wore bad, because they wore brand new, and i even recharged them. the reason that i said that it needs 2000mA is because of the original psp charger, witch puts out exactly 5v and 200mA.
Dec 17, 2008. 3:46 PMawang8 says:
I was talking about your PSP battery... Anyway i'm more used to MintyBoost style things now...
Jun 23, 2007. 5:03 AMTheLobb says:
hmmm workin now. in the altoids. but it only pumps out 2.5 volts....mabye i could use a nine volt and some resistors.
Dec 15, 2008. 9:37 PMawang8 says:
9v batteries are horrible for charging USB-powered devices (or 5v at 500ma) because the internal resistance is so high. Therefore DON'T USE A RESISTOR!! (I'm not shouting, I'm typing in capitals.)
Feb 17, 2008. 3:09 PMNotn4 says:
why do i need a 5v regulator? i got a store bought battery-charger and all it contains is a AAAx4 holder and some wires but no components or stuff !
Dec 15, 2008. 9:35 PMawang8 says:
Because 6v will fry the device. I bought a Belkin 6xAAA charger and it has a chip, regulator and resistor inside it... (and 2 wires and a female USB plug.)
Sep 17, 2008. 5:31 PM466267 says:
Also... Why is the "positive" end of the battery pack going to the input on the regulator?
Because negative is ground?
Oct 7, 2008. 12:19 PMxonsniper4 says:
Why do you need to have a DPDT switch
Dec 15, 2008. 9:31 PMawang8 says:
A toggle switch/rocket switch would be fine I guess...
Sep 19, 2008. 6:04 AM466267 says:
Hey My soldering iron sucks because the tip is broken so how can i solder small metal such as on the switch button etc.?
Nov 1, 2008. 12:59 AMDELETED_evilfrogie says:
(removed by author or community request)
Dec 15, 2008. 9:30 PMawang8 says:
Get a new tip?
Dec 1, 2008. 3:50 PMpiepieburger says:
I am currently building this project. All I have done so far is hook up the positive and the negative wires from the battery case to the regulator. I left the batteries in the case overnight and the regulator got really hot! Will this happen when I'm done and is it a fire hazard?
Sep 19, 2008. 6:11 AM466267 says:
Im confused about this part The output plug and the LED are wired in parallel (if they are in series, the LED will suck up too much voltage, I learned that the hard way) through the switch and the regulator,
Sep 17, 2008. 5:29 PM466267 says:
Hi Instead of using a phone jack ... Can i attach a female usb port ??? Would the wire from the switch go to the positive end of the usb port or negative end ...? Or the neg. wire to the switch with the positive end connecting to the other 3 wires...?
Jul 26, 2008. 11:10 AMLemonyPotatoes says:
1. How long do the batteries last?
2. How many charges can it do, before having to replace them?
3. Can you get all the wiring and switches from Radioshack?
Apr 10, 2008. 1:32 PMloggerhead says:
what happens if you leave it on overnight won't it overload the psp?
Jun 18, 2008. 12:09 AMDerin says:
no it wont we charged a psp for a whole week in a rv no sign of overcharge ps that time is not exactly a weekend i was unplugging the rv from mains everyoften so they go out and play instead of playing call of duty on psp
1-40 of 68next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Jacob S.
