3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
altoids PSP recharger
Step 3Assemble the circuit
assemble the circuit
once the battery pack is installed and the glue has dried you can break out the soldering iron. It uses a extremely simple circuit and I should be able to discribe it, If you have trouble understanding or I just do a bad job of discribing it and the sketch doesn't help, just tell me and I can go more in depth. Here I go.
The output plug and the LED are wired in parallel (if they are in series, the LED will suck up too much voltage, I learned that the hard way) through the switch and the regulator, Just look at the sketch please
once you're done with soldering make sure there is no way that it will short because the whole thing will be crammed into a pretty small space in the end
ONWARD!!!
7 comments
May 15, 2008. 5:47 PMbigt4616 says:
i followed all the directions and everything but i am geting no charge out of the jack
May 25, 2009. 4:37 PMfoxtrot4697 says:
if the orange light isn't lighting up on the PSP it probably is charging, but like he said, it is a bit under power.
Jun 27, 2009. 4:42 PM11richie21 says:
yea i agree because i heard green leds take less power to light than other colors like orange wjite and blue
*white
May 26, 2009. 10:50 AMbigt4616 says:
that really does not make any sense cause it probably has a circuit that lights a orange led when charging the battery. you need a certain voltage or it wont go. i learned this with a little thing i made up for this. it was a salvaged 4 battery pack. i just snipped a usb charger cord and soldered the wires on the pack. when the batteries started to die, they where putting out less voltage(what happends typically when aa's "die" ) they got below the 5V minimum and it stopped charging. i checked it with a multimeter too. btw, you really dont need to put any kind of resistor on the batteries because 6V isnt really going to hurt it that bad, if you need a longer charge, just go with c or d batteries(both 1.5 volts, just more power)
May 3, 2009. 7:06 AM466267 says:
Yo same here but i used usb instaed of jack
Sep 23, 2008. 4:03 PMpolo99a9 says:
me either...
Sep 23, 2008. 4:05 PMpolo99a9 says:
no charge in the psp. is it because the regulator that you posted gives out 5V and only 1000mA? didn;t it need 2000mA? just asking.
Dec 15, 2008. 9:32 PMawang8 says:
Umm... Actually it needs 500mA (max) so the reason it didn't charge is because your battery's toast.
Dec 16, 2008. 5:21 AMpolo99a9 says:
I don't think that my battery wore bad, because they wore brand new, and i even recharged them. the reason that i said that it needs 2000mA is because of the original psp charger, witch puts out exactly 5v and 200mA.
Dec 17, 2008. 3:46 PMawang8 says:
I was talking about your PSP battery... Anyway i'm more used to MintyBoost style things now...
Oct 7, 2008. 12:19 PMxonsniper4 says:
Why do you need to have a DPDT switch
Dec 15, 2008. 9:31 PMawang8 says:
A toggle switch/rocket switch would be fine I guess...
Sep 19, 2008. 6:04 AM466267 says:
Hey My soldering iron sucks because the tip is broken so how can i solder small metal such as on the switch button etc.?
Nov 1, 2008. 12:59 AMDELETED_evilfrogie says:
(removed by author or community request)
Dec 15, 2008. 9:30 PMawang8 says:
Get a new tip?
Sep 19, 2008. 6:11 AM466267 says:
Im confused about this part The output plug and the LED are wired in parallel (if they are in series, the LED will suck up too much voltage, I learned that the hard way) through the switch and the regulator,
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Jacob S.
