altoids ever lasting led lights diy, jackolatern light by ajmboarding
Step 1: Supplies
Here are the following supplies you will need: Altoids can, solder gun, solder,  four 5mm led lights(any color), battery clamp, double sided adhesive tape, 2 AA batteries, a AA battery holder thingy, a little push switch(got mine from an old computers power button, a little circuit bored, and some type of clamp to hold something tight together, oh and some wire
Step 2: Solder in the lights
solder the 4 led lights in a parallel circuit on the circuit bored. look at the picture notes.....
IMPORTANT : make sure when you solder the led lights in you dont have them as high as i have them in the picture or the altoids can may not close.
Step 4: Solder the switch
then solder the another (wire about 2" long) to the second prong . (This is the red wire you see below)
Step 5: Soldering swtich to circuit board
now your going to solder the red wire coming from the battery snap to the + side (where where the longer metal pin was on the led light) and the other wire to the - side ( the side of the led light that has the flat notch in it)
Step 6: Applying adhesive tape
you should now cut a little piece of adhesive tape to the size of the back of the switch, and use a locking clamp to hold the adhesive tape to the switch for a little while to ensure it does not come loose.  also make sure you leave the plastic on the opposite side of the adhesive so it dosnt stick to the clamp.
Step 7: Applying adhesive tape
also add adhesive tape to the bottom of the circuit board and the battery clam. becasue you dont want the metal touching the casing or it willl short it, also it will keep everything in place in the tin can
Step 8: Mounting the switch
now your going to remove the plastic from the adhesive tape on the switch, and clamp it to the edge of the tin. you want to make sure that is is positioned so that when you close the lid it will be pusing the button down. (turning off the lights)
Step 9: Final touches
now you may do the same with the battery casing and the circuit bored, you probably dont need to use a clamp for those though. and once you plug up the battery it should all look like this.
Step 10: Finish
and when you close it, it the led lights should turn off like this
JKPieGuy says: Dec 22, 2011. 11:01 PM
Darn I thought of this idea awhile back but never got to it. Well glad to see someone else thought of the same thing!
andyspam says: Oct 6, 2010. 4:02 PM
To make it turn on when you open it i would suggest a reed switch
ajmboarding (author) says: Oct 6, 2010. 6:03 PM
Yea I know, thanks for the advice. I was really just messin around with my box of-o-fun (junk box of eletronics) to see what I could make and that's all I really had at the time haha.
cowscankill says: Nov 4, 2009. 5:37 AM
That's a really smart way to use a restart button! I never would thing of using it like this, good job.
DIY Dave says: Oct 30, 2009. 6:10 PM
Great job;
I would suggest adding punctuation and correcting spelling. Then the project would be perfect.
ajmboarding (author) says: Nov 1, 2009. 3:59 PM
Ha Ha. Okay. Thanks though.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
