another handlebar digital camera mount
 by def215
Featured
there are a few different instructables on how you can mount a camera on your bike. i found another way to do so. this is my first instructable that i am making, so if there is anything wrong with it, im sorry. so lets get into making a camera mount.
first there are a few things you would need. these are all things that are acquireable around the house, or at the local hardware store for cheap. you will need a hose clamp(make sure it is pretty thick sideways), a 1/4 in. bolt and two nuts, washers, wrenches, a screwdriver, drill and 1/4 in. drill bit.
Step 1: Making the mount
start by getting your hose clamp and flattening it out. once you do that, measure down about 1 inch from the top of where the screw is at thats used to tighten the clamp to the hose. make a mark right at the center of where the one inch mark is at. when that is done, drill a hole into it with the drill and drill bit. when the hole is made, make sure that the hole is clean and deburred. now on to assembly.
daemn22 says: Dec 18, 2012. 9:08 PM
Awesome and very cheap too ^_^
nachiketa says: Mar 27, 2012. 3:52 AM
Nice one 1
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
