loading
Step 5: the bell siphon
i cant tell you exactly how long to cut the cap bottle but you do need some room above the inlet for the water to start the siphon.
This is kind of sexy.
<p>I made the bell siphon with some minor adjustments. </p><p>1) Used a pill bottle with the end of the coke bottle attached to make a funnel shape as the up-pipe (instead of the bacardi breezer bottle) </p><p>2) Used a peanut butter jar instead of the yogurt container and dremeled slots instead of holes. Other than that i followed the instructions exactly and it very surprisingly works perfectly! </p><p>3) I didn't bother attaching the gravel guard out of laziness</p><p>Thanks for the tutorial, it was perfect! </p><p>-</p>
<p>I prefer to see it video </p>
Hey Slamfist; where in the Kootenays are you located? I'm in Nelson and I was wondering if you knew where I could find some Tilapia fry. Thanks! cmlangdon@gmail.com
im actually in trail, i downsized huge and only have 7 fish left but ill ask the lady i got mine from and get back to you. <br>
so just to swell my head a little bit, did anyone actually use my design in there aquaponics setup?? if you did or maybe even improved on the idea i would love to see a picture or two. im now running a huge setup with tilapia but in the process of setting up another outdoor for the summer.
Hey Slamfist, <br> <br>I will be testing something like this out and would love any insight you can offer. I run a program called the Makers' Lab at a private K-8 school and someone came to me interested...I had very little knowledge, but the conversation had me rapid prototyping something today very similar to what you have. Before we open it up to the students I am going to use your instructable as a reference. All pictures will be posted here: https://www.facebook.com/makerslab <br> <br>We even talked about doing trout as the fish so we could eat them. I let them know how incredibly tough it can be to farm trout and suggested Tilapia! Anyways...thanks for the instructable! <br>Matt
One of the problems I've noticed with most of these instructables is a lack of a system diagram. It would help to show how everything is connected in the finished product. I'm assuming the fish are in an aquarium, the siphon draws the water from the the growing tank and the pump, pumps water from the aquarium. Is this correct?<br><br>looks like a fun project and I'd like to try it, but would like to get it right the first time.<br><br>Keep up the great work, and thanks for sharing.<br>
yeah this was my first try at instructibles, sorry for the lack of clarity. if you look at step 7 in the second picture you can see the rubbermaid on the bottom, that is the fishtank, there is a pump in the bottom of the tank that pushes water and waste directly into the growbed/bucket the siphon is then responsible for the flood drain cycle as the water drains back to the fishtank. you cant see it but i had to let the falling water drain into an open ended cup into the tank so there was no actual current in the tank as it was pushing all my duckweed into the pump and taking over the growbed.. if you need anymore help just let me know and i will gladly help you get setup.. thanks
Thanks for the clarification, I now understand. Great job.<br>
How has this been working out for you? Well, I hope.
i have been using this bucket for a couple months now to grow tomatos and they are all happy and growing well, i did have to make an adjustment to the screen that keeps the rocks out of the siphon, but only because i ruffed it up and broke it
I am thinking of making an aquaponics setup myself. Just a couple of questions for you. How often does the water cycle? One of my biggest concerns is root rot. I was curious as to how often your grow bed flooded and drained per hour. I noticed you have a continuous flow fountain pump do you think this would be similar in flow to a water filter aquarium pump (I have one I am thinking of using). I was also wondering how many fish, and are they goldfish?
first off ive been experimenting with different timing on water cycles and it doesnt really seem to make a difference as long as the drain cycle is very fast to add oxygen, the aquaponics forum website says it should be about every 12 mins but mine is about every 4 . my pump is around 75 gph but i have also gotten away with smaller ones and larger ones in the same setup.... as for the fish i have used almost every kind there is from feeder goldfish to pond fish and also edible tilapia, and guppies, they all seem to work about the same the only thing is that you gotta watch your ammonia and nitrate levels in the water, if you get too much nitrates add more plants, not enough nitrates and you need to add more fish! there is also other types of setups using rafts and gutters if you want to know more just gimmie a shout long story short just play around and dont stress it should work out just fine
michaels, a craft store, sells bottle cutters for about 25 bucks
how do you make the bell siphon? Some help please because I'm thinking of making one from plastic instead of PVC.
steps 3-5 show how to setup the siphon its actually very easy, just put a bottle upside down over the funnel bottle on the bottom, it needs to be about an inch taller than the funnel
why do you need the yoghurt container. Can't you do with out it?
the yogurt container keeps the gravel out of the drain it holds it all back so you can take the top off the drain and clean it
did you make cuts to the the bottle. Because I can see you made triangular cuts and also did you glue it the funnel section?
the upside down bottle has triangle cuts in it to allow water to flow, and no they are not glued.. it just slides over top for easy cleaning and adjustment
did you use a glass bottle if so how did you cut it?
its actually a plastic bacardi breezer bottle they are pretty skinny and worked very well because of the odd shape
the fish are just in a rubbermaid tub with a constant flow fountain pump, it has been over 3 months and still no fish death, i actually have been getting 2 crops of romaine lettuce to every 1 crop in the dirt
What about the fish?
About This Instructable
75,788views
84favorites
License:
More by slamfist:diy dirt cheap hepa filter for your vacuum !! aquaponics the cheap easy way!!
Add instructable to:
