loading
it is a simple fun arduino project that let you catch birds , its only for fun .
Step 1: The Body
you will sheets of wood (most likely) but you can use all sorts of stuff like paper ,steel ,plastic ......
i didn't do the measurements but it is pretty simple and I am sure will will do fine.
Step 2: The Material
the electronic material are :
-arduino (14$)
-a servo (4$)
-some jump wires(1$)
-a bred board(3$)
-a push button(0.5$)
Step 3: Wiring It Up
it is pretty simple
Step 4: The Code
just copy past:
#include Servo myservo; // create servo object to control a servo
#define ServoM 12 //Connected to the servo motor. #define In 8 //Pin connected to the IN button. #define BarLow 180 //Low position of the barrier. #define BarUp -90 //Up position of the barrier. #define trigPin 7 //TRING PIN 7 #define echoPin 6 //ECHO PIN 6
void setup(){ myservo.attach(ServoM); // attaches the servo. Serial.begin (9600); pinMode(trigPin, OUTPUT); pinMode(echoPin, INPUT); pinMode(In, INPUT); // set "IN" button pin to input digitalWrite(In, HIGH); // Connect Pull-Up resistor. myservo.write(BarLow); //Barrier in the low position // delay(1000); }
//================================================================ void loop(){
long duration, distance; digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); duration = pulseIn(echoPin, HIGH); distance = (duration/2) / 29.1; //================================================================ if(digitalRead(In)==0) { myservo.write(BarLow);
} if (distance <6) { myservo.write(BarUp);}
Step 5: Finnaly
now it is pretty simple
-the servo controls the door
-the button open the door
- if sonar sensor detect anything closer than 7 cm the door closes
and now it's up to u put a little bol ,fell it with bird food ,put the sonar sensor next to it and wait to catch a bird
hope you enjoy it subscribe for more
<p>Did you actually make this project yet?</p>
<p>why???</p>
<p>yes I did it</p>
It's a bad idea to catch a bird. You don't know what disease does it carry. Something like H5N1 may be carried y the bird and you have a certain chance of getting infected.
<p>thank u for your consern</p>
<p>What will you do with the bird? grill it, or feed it to the cat?</p><p>Consider someone catches you this way</p>
<p>do not be this sensetive I am going to catch it ,feed him, keep it for a while then let it go <br><br>I love animals I have a dog a cat some duks and fishes and frogs</p>
About This Instructable
2,471views
7favorites
License:
More by dani abou zamel:The Best Trick To Teach Your Dog While Walking DIY time-bomb how to teach your dog to sit easely
Add instructable to:
