Arduino Control Leds With a Pot Meter
10,310
8
Published
Introduction: Arduino Control Leds With a Pot Meter
this is just a fun easy project.
Step 1: Parts
1.arduino
2.breadbord
3.usb cable
4. 4 leds
5. 4 330 ohm resistors
6.10k pot meter
7. and fun
Step 2: First
insert al the leds in the bread bord.
Step 3: Then
then you must insert the resistors.
led 1 to pin2
led 2 to pin 3
led 3 to pin 4
led 4 to pin 5
Step 4: Tree
then in sert the pot meter
connect
pin 1 to ground
pin 2 to analogpin 0
pin 3 to +5 v
oke youre al done now yust
the code
Step 5: The Code!!!!
the code i have writen
is below
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    There's also another way to achieve this, but this is also correct and a fun beginners project. The other way to make this cuts down on the amount of resistors. Instead, connect all of your LED's to a single resistor which connects to +5v. Then connect the other side of the LED's to the I/O pins. Then say you want LED 1 on, you would then write that pin LOW, so that current flows through. To turn it off, write it HIGH. Have fun and keep experimenting.
