Arc Reactor
Published
Introduction: Arc Reactor
I will show you how to make a simple, but effective arc reactor.
The items you will need.
- Lid
- misc. wires
- black paper
- hot glue gun
- scissors
- bottle
- LED's
- plastic
- screws
- wires
- battery
- switch
Step 1: Making the Base
I created the base of the arc reactor by taking a lid of a jar. I then drilled a hole in it for the wires to be thread through.
Step 2: LED's
After drilling the hole in the base, I fed wires through it, attaching one to the LED's and the other to a switch which is then connected to a 12 volt battery.
Step 3: LED's
Step 4: Wires
I created 3 small wire circles which will be used in the center of the reactor.
Step 5: Black Ring
I then cut a black circle and painted it black, which was then glued to the body of the reactor.
Step 6: Full Body
I then created the body by attaching three small bits of plastic to the ring, with screws in the middle. A plastic mesh was added underneath. I then placed 2 golden rings above the mesh.
Step 7: Finish
I then glued everything together. Now you're done.
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    That's awesome! I might try a slightly different version with some scrap EL wire I have laying around...
