Introduction: Automatic Fist Bumper
Picture of Automatic Fist Bumper
have you even laid down a sick burn or told an awesome pun and there was no one close enough or brave enough to give you a fist bump? if your answer is yes then this is the project for you.
if you said no... this is still fun to make.
This being my first arduino project i did.
so should not be too tough, all you need is
an arduino, i got a kit from amazon on sale for 50 dollars, it included a small manual a bread board and some extra sensors and leds.(the kit was a vilros.com product and i used the same box so you might see that name a lot)
a p.i.r. sensor, i got it from radioshack for 7 dollars.
a servo which i also got from radioshack for 7 dollars.
and because of the servo i got i need a capacitor (470uf or greater) for it to work, but it your servo might not have the same problems mine had.
for the fist i used
a glove
a small wooden dowel
some stuffing. (i used some scrap fabric)
and hot glue gun.
i did sew the glove back so you will probably need some thread and a needle.
the box just holds the arduino and a breadboard.
i also used some legos to secure the servo in place but i will get to that later. lets get started
Step 1: The Fist Used for Bumping
Picture of The Fist Used for Bumping
i started making the fist by cutting the bottom off the glove off then i cut a slit through the middle on one side.
i hot glued the wooden dowel to the inside of the glove through the slit i cut earlier. i tried filling the glove enough that it would still look like a fist but not so much that the weight would overwork the servo.
i also hot glued one of the servos attachments to the bottom of the dowel. after that it was just the matter of sewing closed the slit and the back of the glove and the fingers down so it would form a fist. one of the things i could of done is add more stuffing for the fingers to make it look more fist like.
Step 2: The Wiring for the Fist for Bumping
Picture of The Wiring for the Fist for Bumping
although the wiring in the picture looked complicated it is pretty simple.
the pir sensors ground is connected to ground .
the pir sensors vcc is connected to pin 13.
the pir sensors out is connected to pin 12.
the servos white or yellow wire connected to pin 4.
the servos red wire is connected to 5v.
the servos brown or black wire is connected to ground.
the capacitor is connected between the 5v and ground.
in hindsight it might have easier if i color coded the wires.
Step 3: The Code for Arduino for the Wiring for the First of the Bumping
this code i got from seraine's instructable(https://www.instructables.com/id/Motion-Activated-S...)
i just made a couple of changes to original code like how far the servo spinned and how fast it moved but that is pretty much it. so special thanks to seraine.
CODE
#include <Servo.h>
Servo myservo;
int pos = 0;
long unsigned int lowIn;
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 12; //digital pin connected to the PIR's output
int pirPos = 13; //connects to the PIR's 5V pin
void setup(){
myservo.attach(4);
Serial.begin(9600);
pinMode(pirPin, INPUT);
pinMode(pirPos, OUTPUT);
digitalWrite(pirPos, HIGH);
Serial.println("calibrating sensor ");
for(int i = 0; i < 30; i++){
Serial.print("-");
delay(1000);
Serial.println();
Serial.println("done");
while (digitalRead(pirPin) == HIGH) {
delay(500); Serial.print(".");
Serial.print("SENSOR ACTIVE");
void loop(){
if(digitalRead(pirPin) == HIGH){
for(pos = 0; pos < 90; pos += 1)
myservo.write(pos); //tells servo to go to position in variable "pos"
delay(5); //waits for the servo to reach the position
for(pos = 90; pos>=1; pos-=1) //goes from 90 to 0 degrees
myservo.write(pos);
delay(50);
if(lockLow){ //makes sure we wait for a transition to LOW before further output is made
lockLow = false;
Serial.println("---");
Serial.print("motion detected at ");
Serial.print(millis()/1000);
Serial.println(" sec");
delay(50);
takeLowTime = true;
if(digitalRead(pirPin) == LOW)
if(takeLowTime){
lowIn = millis(); //save the time of the transition from HIGH to LOW
takeLowTime = false;
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print("motion ended at "); //output
Serial.print((millis() - pause)/1000);
delay(50);
Step 4: The Box Which Contains the Wiring That Uses the Program to Control the Fist of the Bumping
Picture of The Box Which Contains the Wiring That Uses the Program to Control the Fist of the Bumping
i used the the box that the arduino kit came in. i cut a slit near the top to fit the servos wire and one near the bottom for the pir servo to see through. the pir sensor is really sensitive so it will take a little while to make the hole the right size.
i also glued some small pieces of cardboard in the box to keep the board and arduino in place.
the servo is what gave me the most problems during this project. when started the servo would chose a direction at random which way it would spin so i glued legos on each side of the servo and a lego plate to the box so if the servo started spinning the other way i would just flip it over. it also keeps the servo in place without having to glue it down.
Step 5: Now Your Done With the The Box Which Contains the Wiring That Uses... You Get the Point
Picture of Now Your Done With the The Box Which Contains the Wiring That Uses... You Get the Point
enjoy the machine that will not leave you hanging. when you turn it on you just need to wait for at least 30 seconds for the pir sensor to calibrate but after that i will pick up any and every movement.
hopefully your creation will bring as much joy as it has to me
coolkidtn (author)2015-05-29
Awesome! It's fun to see people making such cool projects. Not sure if you could do this but you should add a switch that controls the level of power from the fist bump. For example if you just burned someone hard, turn it on the hard setting from the switch and you get a satisfying fist bump. Haha just getting creative. I will vote for this because its freaking awesome
About This Instructable
261views
2favorites
License:
More by warheroifiam1:automatic fist bumperhow i made my awesome lego mansion
Add instructable to:
