Awesome Lego Machine Gun
11,403
Posted in PlayKnex
Introduction: Awesome Lego Machine Gun
this Lego gun shoots about 20 feet by using a magazine fed flick-fire missile system. warning! youre
eye will hurt if you aim to the face!
Step 1: Find the Parts
the parts are; 8 small red translucent cones, 8 small rods with studs on top, 2 by 6 stud plate/brick,
1 1 by 14 rod with 13 holes,1 1 by 10 rod with 9 holes, 1 small Grey connector that fits into the holes
on the rods, 2 long black connector that fits into holes on the rods, 1 7 hole rod with no studs, 2 11 hole rods with no studs. https://www.instructables.com/files/deriv/FGH/0813/FQCTO2AE/FGH0813FQCTO2AE.TINY.jpgthat's all you need to build it.
Step 2: Make the Ammo
use the Grey rods and red cones to make missile-like ammo. use all the cones and rods to make 8.
Step 3: Build the Base
to build the base part, connect the 13 hole rod with 14 studs to the 9 hole rod with 10 studs so there is 2 studs on either side of the 13 hole rod. then, use the 2 by 6 plates to cover up 4 studs on either side of the 9 hole rod. finally, insert the long black rods into the 13 hole rod so there are 5 holes on either side and 1 hole in between.
Step 4: The Magazine
insert the small Grey rod into one of the 11 hole rods and snap the other one onto the Grey rod on the end.
Step 5: Attaching the Magazine
put the base on its side and put the magazine on the base so the rod sticking up goes in between the long black rods and the 2 by 6s. then snap everything into place by snapping on the 7 hole rod on it so there is 2 holes on either side.
Step 6: Loading It
now to load it, put the ammo into the magazine FROM THE TOP TO BOTTOM! it should stop at the 9 hole rod.
Step 7: Fire!!!!!!
to fire, quickly flick the back of the missile on the bottom. do this while holding it don't touch the magazine while holding it. i am NOT responsible for any hurt fingers. hope you like it, bye!
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    37 Comments
    ,,It would be a good,, starter ,,Lego gun,, pretty cool
    You might of repeated it 100000 times but its cool
    Not so good:P
    ,, hi ,,
    lts totolly awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    i dont mean to be mean or anything but its a sub machine gun. although a machine gun with a chain would be the best lego gun EVER!
    http://mocpages.com/home.php/13860if you want to see REAL AWESOME lego guns go to the link here ^ you should look at his guns and his videos
                                                         l
    they are the most epic thing you will ver see in ur life o.O
    to be honest it is not really a gun it is more of a flick thing and parts go everywhere. a really gun made of costruction is a knex like what i build.
    use something else to flick the lego pellets
    u type it ;)
    what i ment was that you type the tags they're not im a directory or something
    nless i dont know somthing o.O
    mini type dont work? lets see
    ...how do u mini type? can u teach me hao to do it plzzzzzzzzzzzzz?
    you put 2 commas before you type what your going to say then 2 commas after you typep what you wanna say ill use Periods to show an example .. like this but with commas instead of periods..
