This awesome mood light looks great and is easy to make it also uses recycled materiel's.
Step 1: Step 1 Hacking The Light-Saber
I found this light-saber lying around and thought it would make a great mood light as it had all the colors used in making one (green blue red). you can find these light-sabers everywhere from 2 dolor shops to bins and skips. once you have found a good one with all colors needed its time to start. find the screws that hold it together and undo them when you do that cut the led board away from the rest of the circuit and remove the tube.
SexySTUD.nu.1 says: Aug 27, 2012. 12:44 AM
fwiw i like this ible. good job OP. Mahmoud Alaa, I believe your being negative in the freedom dimension. Try to not be so rude this is a place for creativity. :)
Mahmoud Alaa says: Aug 16, 2012. 1:50 AM
mine is more easier and glower , you can see my able  here
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
